delay curcuit for turn signals
Postby jeff0520 » Sat Oct 27, 2012 9:00 am
Hello all,
I have come up with an interesting idea for turn signals on the Command Post. I am going to use two of these: http://www.superbrightleds.com/moreinfo/id-bars/braketurn-light-bar-tlb-r11/1027/2482/ One on each side. They are actually meant for the back luggage trunk on a big touring motorcycle, so they are split in half, one side for each turn signal. The command post has a standard 4 wire trailer wiring harnass, so I'm thinking that if I could build a circuit with one input for the brake/turn wire, with two outputs with a half second delay on the second output, I could create a hillbilly version of the mustang sequential turn signals. Since there is no flasher in the curcuit I'm thinking of, it wouldn't mess with the brake light function.
Any idea on how to do that? :thinking:
Hypno-Toad's Command Post, the build thread! http://www.tnttt.com/viewtopic.php?f=50&t=50384
jeff0520
Images: 128
Re: delay curcuit for turn signals
Postby Greg M » Sat Oct 27, 2012 11:49 am
The problem I see is that the second light will hardly come on at all. The length of the turn signal from the TV probably isn't much longer than 1/2 second to start with. That said, a short delay could easily be added with a 555 timer circuit wired inline with the second light's input. Google 555 timer circuits and you'll find tons of plans.
-Greg
Greg M
*Geek Extraordinaire
Images: 85
Postby jeff0520 » Sat Oct 27, 2012 3:28 pm
Greg M wrote:The problem I see is that the second light will hardly come on at all. The length of the turn signal from the TV probably isn't much longer than 1/2 second to start with.
-Greg
Good point. I suppose I'd better figure out how long the turn signal interval is in the first place
jeff0520
Images: 128
Postby eamarquardt » Sat Oct 27, 2012 3:58 pm
Thinking about it I had a lot of thoughts.
First) It might look odd if all the lights aren't the same brightness.
Second) As been bought out, getting the timing right will be tricky.
The lights themselves are $60 then you have all the cost, time, and effort to build a 555 timer and a switching circuit that the timer controls. PITA.
Found this on EBay: http://www.ebay.com/itm/Sequential-LED- ... 00&vxp=mtr
Seems like all the hard work has been done for you and you could have THREE sequential lights. More cooler!
Then purchase these or similar lights: http://www.ebay.com/itm/4-Red-10-LED-6- ... 1f&vxp=mtr
By the time the dust settles you'll have about the same invested but with far less hassle.
Hope this helps.
Gus
eamarquardt
Images: 150
