Brown Wire / Running Lights
Postby schreibers » Wed May 22, 2013 10:24 am
Just a simple question when connecting your 4 side markers + tail lights + license plate light are you using a bus bar from the incoming brown wire (in my case coming from a modulite module) or are you daisy chaining the positives from each light to the next?
The way most diagrams are drawn they don't really differentiate so I wanted to make sure. I assumed with the high amp converter chaining would be fine then using separate grounds.
Thanks
schreibers
Re: Brown Wire / Running Lights
Postby starleen2 » Wed May 22, 2013 10:43 am
I used in line splices to avoid extra lines to a buss bar
starleen2
5th Teardrop Club
Postby GuitarPhotog » Wed May 22, 2013 3:05 pm
starleen2 wrote:I used in line splices to avoid extra lines to a buss bar
Those things are the spawn of the devil! Guaranteed to fail when you need them most.
A failure where the hitch installer connected mine caused an electrical fire in my trailer last fall!
I suggest you either learn how to solder and make proper soldered connections, or buy a proper crimping tool and use crimps. But I strongly suggest you avoid those insulation displacement connectors at all costs.
<Chas>
:beer:
GuitarPhotog
Images: 55
Postby schreibers » Wed May 22, 2013 3:18 pm
Thanks for the help I agree I've fixed many a car audio install due to improper T-Tap usage I'll just solder splices.
Thanks again
schreibers
Postby George Taylor » Wed May 22, 2013 9:32 pm
<Chas>
:beer:[/quote
Yep
George Taylor
