How do you vent your battery (s)
Postby Ron Dickey » Wed Sep 04, 2013 12:30 pm
I am working on where to put my batteries and am working on where to put them.
(I do not have the batteries yet I am still working on that part too see viewtopic.php?f=30&t=57154)
That being said, Venting should be part of the design. And therefore the question comes to mind, of those of you who have batteries in your trailer how do you vent it.
:roll:
I also wondered it anyone has made the vent part of the trailer design like those cool looking air vents you see on the side of cars?? 8)
Ron Dickey
173882......173887
Ron Dickey
Images: 787
Re: How do you vent your battery (s)
Postby absolutsnwbrdr » Wed Sep 04, 2013 1:11 pm
Mine hang underneath in bolt-together cages that I fabricated from slotted steel angle. No venting required, and they're out of the way.
Zach
Coming Soon...
absolutsnwbrdr
Images: 412
Postby les45 » Wed Sep 04, 2013 2:07 pm
My initial plan was for the battery to be in the rear under the galley counter so that all my AC/DC wiring were in close proximity to my electrical cabinet. I became concerned about venting, but I also needed tongue weight. Ended up using a conventional battery box on the tongue so venting was not an issue. Just had to make a longer run of primary DC wiring from front to back and I did that inside the cabin using Wiremold conduit under the mattress.
les45
Images: 605
Postby Lgboro » Wed Sep 04, 2013 2:28 pm
Mine is under my tear also. I wouldn't want to use my dry space for a battery even if it didn't need venting:thinking:.
Lgboro
Images: 53
Postby halfdome, Danny » Wed Sep 04, 2013 5:24 pm
Ron, Mine are also under the floor in these bolt - in - battery boxes.
:D Danny
halfdome, Danny
*Happy Camper
Images: 252
Postby dguff » Wed Sep 04, 2013 8:22 pm
Don't vent and don't need to vent. I use an AGM sealed wheelchair type deep cycle battery. No vents in it. I do have it mounted in the tongue box but could put it anywhere.
Jerome
Jerome
2008 Guffman
dguff
Images: 69
Postby nevadatear » Wed Sep 04, 2013 8:28 pm
Out the back of the tongue box. Openning covered with plastic mesh, i think from a gutter cover. Hidden by the tear. About 1" gap between box and tear.
nevadatear
Images: 171
Postby Roo Dog » Wed Sep 04, 2013 9:23 pm
Wot Jerome says.
Mounted inside under the galley deck.
RD :)
Lets do a three sixty and get out of here !
Roo Dog
