I'm in the final stages of my build and would like the benefit of the forum's experience to review my plan and raise any warning flags.
My battery and Progressive Dynamics charger/converter will be in my tongue box and fed by a Marine on-board charger inlet. I plan to run my 8 Ga. feed lines through a Perko Marine deck connection at the nose of my tear, through the roof spars to a Progressive dynamics distribution/fuse box in the galley raceway. I am using stranded wire and do not plan to use any conduit. There will only be 12 volt wire in the roof and I will run about 6 inches from the roof edge to be sure not to nail into it. Is there anything about this set up that I have overlooked?
