So I'm scratch building my own trailer. I'd like to run the 7-plug wiring harness through the tongue so it exits under the trailer somewhere from which point I'll split out from a junction box. This is mostly for cosmetic reasons - keep it clean looking, less wires dangling around the frame, etc. but also to keep it protected.
Question is: What's the best way (and location) to get the harness into the tongue framing? Drill a hole on the bottom of the main tongue frame member? Is there any sort of commercial grommet or anything for this purpose to keep the frame from rubbing the wiring?
Any pros/cons to running it in the frame vs underneath?
Thanks in advance.
