Running wiring harness through tongue framing
Anything electric, AC or DC
Postby javajaws » Wed Mar 25, 2015 4:47 pm
So I'm scratch building my own trailer. I'd like to run the 7-plug wiring harness through the tongue so it exits under the trailer somewhere from which point I'll split out from a junction box. This is mostly for cosmetic reasons - keep it clean looking, less wires dangling around the frame, etc. but also to keep it protected.
Question is: What's the best way (and location) to get the harness into the tongue framing? Drill a hole on the bottom of the main tongue frame member? Is there any sort of commercial grommet or anything for this purpose to keep the frame from rubbing the wiring?
Any pros/cons to running it in the frame vs underneath?
Thanks in advance.
javajaws
Re: Running wiring harness through tongue framing
Postby halfdome, Danny » Wed Mar 25, 2015 5:27 pm
I've done it both ways.
I now prefer to run the wires under the exterior of the tongue/draw bar through several angled pieces welded to the tongue/draw bar to look like this ^.
Easy to get to, no drilling into the cross member, and very serviceable.
I place my junction box in the center of the first cross member.
:D Danny
halfdome, Danny
*Happy Camper
Images: 252
Postby javajaws » Wed Mar 25, 2015 5:38 pm
How did you attach the cable? Zip ties?
javajaws
Postby H.A. » Wed Mar 25, 2015 6:59 pm
:goodnight: [
H.A.
Postby George Taylor » Wed Mar 25, 2015 8:20 pm
I found a generic rubber grommet in the drawers in the screw isle at lowes.
George Taylor
Postby halfdome, Danny » Wed Mar 25, 2015 8:36 pm
javajaws wrote:How did you attach the cable? Zip ties?
My cable goes through the angle iron pieces that are welded to the tongue/draw bar.
:D Danny
halfdome, Danny
*Happy Camper
Images: 252
Postby javajaws » Wed Mar 25, 2015 10:11 pm
H.A. wrote:One thing thats amusing is the "build to Space Shuttle quality standards" what many promote.
Sinking huge dollars and hours into something for a simple camping trip.
True enough.
Sometimes though the journey can be as fun as the destination. And there's nothing wrong with taking pride in one's work - if that sort of thing floats your boat.
javajaws
Postby javajaws » Wed Mar 25, 2015 10:14 pm
halfdome, Danny wrote:My cable goes through the angle iron pieces that are welded to the tongue/draw bar.
So the angle iron is on the bottom in a V (not a ^)?
Since my build is more offroad oriented I'm thinking running the cable along the bottom is probably not a good idea. :)
I'll probably have to stick to inside the tongue or along the side
javajaws
Postby Dale M. » Thu Mar 26, 2015 6:25 am
Put it inside a length of conduit anchored to tongue....
Got to be a million ways to clamp/weld conduit to tongue...
Not a real fan of drilling large holes in tongues, as it may cause stress risers, and eventual breakage...
Dale
Dale M.
Images: 18
Postby bobhenry » Thu Mar 26, 2015 7:12 am
All of my builds in which the wiring has ran under the coach is in schedule 80 pvc.It is bullet proof and
NON CONDUCTIVE .
Return to Electrical Secrets
Users browsing this forum: Google [Bot] and 0 guests
