NT 5X8 trailer on sale (my experience)
Re: NT 5X8 trailer on sale (my experience)
Postby drewh1 » Mon Aug 05, 2013 10:11 pm
thanks!
"If only I knew what I know now when I started . . ."
My Build Journal http://www.tnttt.com/viewtopic.php?f=50&t=56916
drewh1
Images: 7
Postby drewh1 » Fri Aug 30, 2013 2:59 pm
this posting has been a big help to me, and I have yet another quick question - I am trying to figure out what size Stabilizers to order for the trailer, choice is 11 - 15" or 15 to 21".
Nowhere do they say what the height of the trailer is. I was hoping you could tell me which jacks you ordered.
drewh1
Images: 7
Postby les45 » Fri Aug 30, 2013 5:32 pm
drewh1 wrote:this posting has been a big help to me, and I have yet another quick question - I am trying to figure out what size Stabilizers to order for the trailer, choice is 11 - 15" or 15 to 21".
Not sure what brand you are looking at, but mine are Atwood and there are a lot of them on Ebay. They all show a range of about 11" - 17" and that is what mine are. My NT 5X8 trailer clearance is 16.5" at the rear frame channel. I use wood blocks under the feet to give me a little more range and to keep them clean. I bolted mine to the rear cross channel and in line with the channel so the feet extend out beyond the side frame when fully extended. I only installed two at the rear and I use the TV hitch or a jack stand on the front. That keeps it plenty stable even when we are moving around inside. Like everything else on this forum, there are a lot of very different opinions about how many and what configuration to use for these stabilizer jacks so you need to do some homework and decide for yourself.
les45
Images: 605
Postby drewh1 » Fri Aug 30, 2013 5:41 pm
I have been looking at the Atwood. Really just needed the ground clearance, thanks for the quick response. I will use the same type of config, 2 stabilizers in the back and the wheel jack in the front.
Bought router bits and rough cut the plywood sides so I am off and running!. I'll order my NT when I get back. They were on sale a month ago but I didn't buy one, should have :x
drewh1
Images: 7
