NON Fisheye Shots Of the Kasperwing Project
Postby skacutter » Sun Apr 30, 2006 10:00 am
By popular demand here is a link to non fisheye shots of the tiny travel trailer
http://www.kasperwing.com/No%20Fisheye.htm
I have the hitch mount on and was able to tow the trailer around the yard over some bumps. The leaf springs did not bottom out.
Regards
Chris
please visit the Kasperwing site and click on the teardrop trailer link
skacutter
Re: NON Fisheye Shots Of the Kasperwing Project
Postby Micro469 » Sun Apr 30, 2006 10:55 am
skacutter wrote:By popular demand here is a link to non fisheye shots of the tiny travel trailer
Regards
Chris
The things we make you do.... :lol: Crawling around on your stomache to take a few pics.... :lol: :lol:
John
Micro469
Images: 382
Postby Chris C » Sun Apr 30, 2006 11:20 am
Thanks. That should make it easier to answer your questions. :applause:
Chris :D
Chris C
Postby Kevin A » Sun Apr 30, 2006 11:39 am
Chris,
It doesn't look like it's possible for the u-bolts to contact the frame, they are outside of the frame rails.
Kevin A
The other guy
Images: 289
Postby asianflava » Sun Apr 30, 2006 1:05 pm
Ahhh, much better straight lines are straight. :thumbsup:
Now it obvious that the bolts won't hit. The springs do look flat though. I guess you'll be fixing that soon.
asianflava
Postby Nitetimes » Sun Apr 30, 2006 7:06 pm
That particular spring generally doesn't have a real deep arch but it does seem like the tail pieces hang down quite a bit more than normal so they may have had a deeper arch originally. I would do two things, 1- Check the leafs very close between the u-bolt, right where the pinch bolt goes up thru the spring for cracks, if you don't find any go to step 2. Second thing is get it weighed, if it's under 2k lbs leave 'em be, those are 1500 or 1750lb (ea) springs, you'll have plenty of spring anyway.
Rich
- Thomas Jefferson -
Nitetimes
7000 Club
7000 Club
Images: 194
