by Nitetimes » Sun Apr 30, 2006 7:06 pm
That particular spring generally doesn't have a real deep arch but it does seem like the tail pieces hang down quite a bit more than normal so they may have had a deeper arch originally. I would do two things, 1- Check the leafs very close between the u-bolt, right where the pinch bolt goes up thru the spring for cracks, if you don't find any go to step 2. Second thing is get it weighed, if it's under 2k lbs leave 'em be, those are 1500 or 1750lb (ea) springs, you'll have plenty of spring anyway.
Rich
![Image](http://www.teardroptrailers.us/images/terrible%20towel.jpg)
- Thomas Jefferson -
