Wheel hub question
Wheel hub question
Postby danlott » Tue May 05, 2009 11:21 am
Looking to buy an axel and came across this one that would work for me. Just don't know that much about hubs. It says that it has brakes and 4-lug 4" diagonal bolt pattern. The brakes seem kind of small and I am not sure if I will be able to get 15" wheels in that bolt pattern. How common is the bolt pattern and what do you guys think about the brake size?
Dan
Hoplite Traveler Build thread
danlott
Images: 264
Postby Nitetimes » Tue May 05, 2009 1:31 pm
If you look around I'm sure you can find 14" and maybe 15" wheels to fit them but 13" would probably be easier. Now here's what you need to watch, the 4 high spots are the only place the wheel is going to hit on that hub so aluminum wheels are your best bet as they are mostly flat on the hub surface, a lot of steel wheels might not sit right on it and it leaves you open to cracking the wheels. There are about 4 different styles of those 7" brake hubs, 2 5 bolt and 2 4 bolt, and you need to make sure the wheel mates up with that particular hub.
Otherwise that is a perfectly usable axle, although I don't care for those small brakes myself, but that's probably because I repaired them for so many years.
Rich
- Thomas Jefferson -
Nitetimes
7000 Club
7000 Club
Images: 194
