by eamarquardt » Fri Mar 12, 2010 5:33 pm
Usually axles w/o brakes have just hubs, not brake drums. So in addition to the brake shoe assembly you'll need drums to match. Brake hubs usually come with the outer bearings pressed in and you can use the cones and inner races from your existing hubs. Then you'll need to make sure you have a battery in your teardrop and a breakaway switch to connect the battery to the brakes in the event your trailer and tv become separated. Finally you'll need a brake controller installed in your tv to control the trailer brakes. Then it's easy bolt on/wire in installation.
Hope this helps.
Cheers,
Gus
