dxf drawing of a HF 90154 1195lb 4x8 trailer
Postby d_lairson » Thu Feb 18, 2010 4:02 pm
Does anyone have a dxf drawing of the harbor Freight 90154 1195lb trailer. I saw that it is on sale at HF, plus if I could use a 20% off coupon on top of that it puts it squarly in my price range at present. I'm building a 5' wide and wondering how high over the top of the frame the tires stick up, I basically am trying to see the impact of the wheels on the sleeping area.
Thanks
d_lairson
Postby mikeschn » Thu Feb 18, 2010 4:32 pm
Does this help?
Postby d_lairson » Thu Feb 18, 2010 5:06 pm
Mike,
That does help some. My real question is the height of the tire over the top of the frame... I would be moving the tire back to get proper placement I'm just trying to figure out the intrusion into the cabin. I may just have to break down and go to the store, they have a pretty good deal on saw horses and I need to pick up a couple anyway.
Thanks!
d_lairson
Postby mikeschn » Thu Feb 18, 2010 5:18 pm
Hmmm...
How tall is that tire? I don't have one to measure... Who can tell me the diameter of a HF 12" tire?
Postby starleen2 » Thu Feb 18, 2010 5:28 pm
Its the same as a Carry-on tire at 20 1/2 inches (rim to rim 13")
starleen2
5th Teardrop Club
Postby mikeschn » Thu Feb 18, 2010 5:33 pm
d_lairson wrote:Mike,
I would say 2 5/8" based on Scott's information.
Postby d_lairson » Thu Feb 18, 2010 5:38 pm
Does anyone have an idea of how much movement (up and down) that there might be on a set up like this?
d_lairson
Postby bobhenry » Thu Feb 18, 2010 6:34 pm
Ok I can answer this one......
From the spring perch I have a 2" frame (junked the bent HF frame)
I laid down 3/4 floor and cut around the tire I built a 1 1/2 wheel well and topped it with 3/4 and it clears the 12" tire. I unfortunatly left the stock fender under the wheel well to "protect the floor " and a bolt cut the tire IN HALF. SO 2" frame plus 3/4 floor plus 1 1/2 spacer for wheel well is
4 1/4 I get a couple rub marks but my tear is 1100 to 1200 lbs.
Safe number is 5"
Postby mikeschn » Thu Feb 18, 2010 6:37 pm
d_lairson wrote:Does anyone have an idea of how much movement (up and down) that there might be on a set up like this?
I typically allow for 3" of movement in the up direction.
d_
What cad system are you on?
Postby synaps3 » Thu Feb 18, 2010 6:40 pm
I have a (slightly modified) .skp of the 1700lb model. It's quite similar... PM me if you want it.
-- Dave
Build log: here
synaps3
Images: 254
Postby d_lairson » Thu Feb 18, 2010 7:01 pm
d_
I'm using DoubleCAD XT, I downloaded it free somewhere...
d_lairson
Postby mikeschn » Thu Feb 18, 2010 7:07 pm
d_
That's supposed to be Autocad compatible. So tell me if you can read this...
http://www.mikenchell.com/images/4x8hf.dwg
Postby d_lairson » Thu Feb 18, 2010 8:21 pm
mikeschn wrote:
d_
No dice... It recognizes and opens the file but gives an error saying some components are not supported and gives me an empty drawing.
Is there anyway I can upload a file for people to look at? I cobbled together a quick drawing as a proof of concept sort of thing with some measurements and components from other drawings. I thought I would see what people think. I have not done any drafting since high school / college and that was all on paper, so the drawings might be a little rough.
d_lairson
Postby mikeschn » Thu Feb 18, 2010 8:42 pm
We don't have a file repository, YET. But if you send me the file, I can post it for you.
Postby d_lairson » Thu Feb 18, 2010 9:44 pm
mikeschn wrote:We don't have a file repository, YET. But if you send me the file, I can post it for you.
Ok, great.... how do I get it to you....
David
d_lairson
