KCStudly wrote:I don't think you need the center tongue member, eliminate it and set the outer tongue rails to 50 deg apart; that's the std coupler angle for weld on.
Take a real close look at the stabilizer jacks that you intend to use. You may find that the 5 x 5 plates aren't as big as you think they are when they are up against the frame rail tubing.
KCStudly wrote:Have you seen my build? I have my trailer built with a 50 deg tongue frame and custom swivel coupling. Frame is 99% done and am just starting in on the cabin.
Have fun!
crpngdth2001 wrote:I just read through the entire thread, absolutely amazing work on the frame. The coupler is a work of art too - but if I go that route, it will certainly be something 'off the shelf'. I think I might have read your TV is a Jeep, is that right? Mine is a 2005 Jeep Wrangler Rubicon Unlimited.
Again, thanks for the input and look forward to progress on your cabin.![]()
Jim
