TJinPgh wrote:For my purposes I don't think axle rating is going to be a huge issue. The final product needs to be well under 1000 pounds, including gear.
I'm sure it sounds like a 3500 lb axle is plenty enough for a 1000 lb trailer. Which it is.
The problem is that a 1000 lb trailer will barely make 3500 lb springs flex at all, so you would have virtually no suspension. So everything inside will get thrown around, the body will get a terrible pounding and each time you drive over a bump, the trailer will go into low earth orbit for 10 seconds.
A 1000 lb trailer on 2000 lb springs is OK, but after that the overkill is actually bad news.
I know you've decided not to use this axle - but I just had to get that lot off my chest.....
