Folks,
TSC New Jersey site is Washington NJ NOT Washington NY...sorry!
Jim
kayakrguy wrote:......What I am uncertain about is why it is necessary to change where the axles attach. I realize there are rules of thumb about where the axle weight should fall--60x40--etc. Is there a problem with this with the RT as delivered?...........
Also, IF one DOES move the axle just what minimum of tools does one need to accomplish that? And, as a sidebar...if I put a metal cutting blade in my mitre saw can I cut angle supports as in transforming the RT to a rigid configuration?
kayakrguy wrote:Thank you for the advice and information. I am curious about the Red Trailer modifications. Those dealing with making it rigid and not foldable I get.
kayakrguy wrote:Also, IF one DOES move the axle just what minimum of tools does one need to accomplish that? And, as a sidebar...if I put a metal cutting blade in my mitre saw can I cut angle supports as in transforming the RT to a rigid configuration?
rampage wrote:i have a question about the wood brace. should you use pt lumber? or put a coating of something on it? i'm doing mine tomorrow and i'm gonna use pt lumber if i dont hear from anyone on this. thanks
