SteveH wrote:Yes Jack, and after seeing a CampInn frame a year or so ago, even my frame is about four times as strong (read HEAVY) as it needs to be.
Cary Winch wrote:Andrew,
Your memory is not as filled with cobwebs as you think. We did have a extreme off road frame that was 3/16" thick. But it was also 2 1/2" x 2 1/2" angle rather than 2". Those were very heavy and very strong. Otherwise we use the 2 x 2 x 1/8". The Raindrop is a different beast though, we add in tensional members to give it some box strength. Just steel rod and is a great light weight solution. You'll have to see on some time.
Cary
