Frame Report After 12K miles
Postby SteveH » Tue Sep 26, 2006 1:42 pm
Way back in November of '04 when I started building my trailer, I reported in this thread: http://tnttt.com/viewto ... highlight= I was building the frame from 2" X 1/4" angle iron. There were several folks on the forum that had...lets just say they had lots of "concerns" about the strength of an angle iron frame. I am happy to report that after almost two years of use and over 12,000 miles of travel, there have been absolutely zero issues with the frame, or any other part of the teardrop structure, for that matter. I am here to testify that 2" angle is plenty strong for the frame of a teardrop trailer, again IMHO.
SteveH
SteveH
Images: 42
Postby madjack » Tue Sep 26, 2006 4:49 pm
...that is good to hear Steve...during my time here, I have come to believe that we severely overbuild our frames...a frame such as on Mikes UltraLite or Freds new AlaskaLite design, is more in line with what we are building....
madjack 8)
Postby SteveH » Wed Sep 27, 2006 6:44 am
Yes Jack, and after seeing a CampInn frame a year or so ago, even my frame is about four times as strong (read HEAVY) as it needs to be.
By the way, if anyone is interested, there are pictures of my frame in my album.
SteveH
SteveH
Images: 42
Postby bledsoe3 » Wed Sep 27, 2006 7:00 am
Thanks for that update. IF I ever build another, I'll be doing it lighter.
bledsoe3
Images: 112
Postby angib » Wed Sep 27, 2006 10:50 am
SteveH wrote:Yes Jack, and after seeing a CampInn frame a year or so ago, even my frame is about four times as strong (read HEAVY) as it needs to be.
Can anyone say that the Camp-Inn frame is definitely 2" x 2" x 1/8" angle? And can someone say what the distance is from the front of the body to the centre of the ball?
I seem to remember Cary saying they once had a 3/16" thick option for 'off-road' use - but that infomation has travelled through the filter of my memory....
Andrew
angib
5000 Club
5000 Club
Images: 231
Postby SteveH » Wed Sep 27, 2006 12:45 pm
Andrew,
I've seen the CampInn frame, and yes, it is definately 2" X 2" X 1/8" angle, and it has a very minimal number of cross members...like two if I remember right. The V tongue, also angle, is butt welded on at the junction of the side pieces and the front cross member.
SteveH
SteveH
Images: 42
Postby jdarkoregon » Wed Sep 27, 2006 11:57 pm
SteveH
Thanks for the report, When I build a single axle tear, it will be light and your information about the material of the frame will be very comforting.
thanks again
John ;)
Innovation is essential
The world can be better
jdarkoregon
Images: 47
Postby angib » Thu Sep 28, 2006 12:00 pm
One comment I'd make on Steve's frame is to point out that he's using 2"x2"x1/4" angle - and this is twice as strong as 2"x2"x1/8" angle. We don't want anyone to go thinking that all 2" angles are the same.
It's also worth adding that the 2"x2"x1/4" angle Steve is using is actually heavier than the 2"x2"x1/8" square tube that other folks have used.
As well as what it's made from, the length of the tongue matters a lot in its strength - the longer the tongue, the stronger it needs to be.
Andrew
angib
5000 Club
5000 Club
Images: 231
Postby Cary Winch » Thu Sep 28, 2006 2:29 pm
Andrew,
Your memory is not as filled with cobwebs as you think. We did have a extreme off road frame that was 3/16" thick. But it was also 2 1/2" x 2 1/2" angle rather than 2". Those were very heavy and very strong. Otherwise we use the 2 x 2 x 1/8". The Raindrop is a different beast though, we add in tensional members to give it some box strength. Just steel rod and is a great light weight solution. You'll have to see on some time.
Cary
Cary Winch
Teardrop Manufacturer
Postby alaska teardrop » Thu Sep 28, 2006 2:50 pm
    It might also be pointed out that the 2"x2"x1/8" sq. tube is about 2 1/2 times stronger than the 2"x2"x1/4" angle. And that it allows more end area for stronger less flexible welds.
    Like others, I designed my first TD before coming upon Mike's T&TTT and had searched for some kind of chassis standards without success. Although I can say that the overall trailer is light, the frame could have been considerably lighter.
    So, thankyou Mike, Paul & Andrew. We now have a realistic way of comparison and design standard. :applause: :thumbsup:
alaska teardrop
Postby bledsoe3 » Thu Sep 28, 2006 11:33 pm
Cary Winch wrote:Andrew,
Cary
Cary, That's 2" X 2" X 1/8" angle right?
bledsoe3
Images: 112
Postby Cary Winch » Fri Sep 29, 2006 9:00 am
Yup, that is angle.
Cary
Cary Winch
Postby TRAIL-OF-TEARS » Mon Oct 02, 2006 3:20 pm
Sorry to respond so late. But we just got back from a 2000 mile trip to Colorado. I have about 9000 miles on my tear and it was built with 2x2x1/4" angle set up very close to the Camp-Inn style. This trip the tear was very heavily loaded about 1600lbs total and most of the weight was in front of the axle. I am happy to report we had no problems on this trip.
Steve J.
Home built Camp-Inn clone.
GO SPURS GO
TRAIL-OF-TEARS
Images: 41
