15" wheels and tires on tractor supply 4x8 no floor tra
Postby Bill_Storey » Sat Jul 05, 2008 10:00 am
Has anyone put 15 inch trailer rims and tires (0 offset) on the tractor supply 4x8 no floor trailer? If so, what size tire did you use, and how much clearance did you have between tire and frame?
I have aquired a new set of rims that were bought from Southwestern Wheel and then never used.
The reasons I want to use 15 in rims is three fold;
1. I like the look better with 15 in rims.
2. It will slightly raise the trailer weight capacity.
3. It will allow the bearings to run a little slower and / or me to tow a little faster.
Truthfully, it's more about looks than anything else. I had to reach to think of reasons 2 and 3.
Bill_Storey
Postby madjack » Sat Jul 05, 2008 10:37 am
#4...less rolling resistance
#5...better pothole resistance...
Bill, I haven't used a HF frame so can't directly tell ya but clearance would be your biggest problem...if you have the wheel/tire combo, then check for clearance...oh yeah...most of the HF frames have a 4lug hub and the 15's are probably 5 lug, so some sort of an /spacer/adapter is needed anyway...we run 205-70-15 car type tires on ours(and most of the trailers around the shop)
Postby Kens » Sat Jul 05, 2008 2:01 pm
Madjack TS frame.
Good day every day!
Kens
Images: 26
Postby angib » Sat Jul 05, 2008 3:37 pm
madjack wrote:#4...less rolling resistance
I think you'd be shocked by how much more rolling resistance larger tyres have.
Just swapping the wheels/tyres on most cars for the ones on the economy model is worth a several mpg gain.
Andrew
angib
5000 Club
5000 Club
Images: 231
Postby Alphacarina » Sun Jul 06, 2008 10:48 am
Certainly true when you compare 15 inch tires with the recommended 30 PSI in them with the 12 inch tires running the recommended 80 PSI
No question which one is easier to roll ;)
Don
Alphacarina
Postby madjack » Sun Jul 06, 2008 1:53 pm
Don
...yeahbut, yeahbut, yeahbut....wattabout the "gyroscopic flywheel" effect kicking in once the tires ARE rolling :o :D ;)
Postby mechmagcn » Sun Jul 06, 2008 2:25 pm
My preference to run larger tires on my teardrop comes from the fact that the larger the tire, the less of a beating then trailer takes from rough roads, and we all know what shape the roads are in nowadays :lol:
Jeff & Micki
53 F100
Mercedes turbo diesel
Teardrop "finished" as if they ever are
You can never be lost if you don't care where you are going!
mechmagcn
Images: 56
Postby angib » Sun Jul 06, 2008 3:13 pm
madjack wrote:....wattabout the "gyroscopic flywheel" effect kicking in once the tires ARE rolling
Yeah, but that just beats seven grades of **** out of your dilithium crystals.....
Andrew
angib
5000 Club
5000 Club
Images: 231
Postby brian_bp » Mon Jul 07, 2008 6:08 pm
Larger diameter tires should be better for rolling resistance, but larger tire width is worse.
The Tractor Supply Carry-On 4 ft. x 8 ft. Trailer, 1500 lbs. GVWR is described on their web site has having "12 in tires rated 990 lbs each". With that capacity at 80 PSI, I'm guessing the tires are what they sell as Trailer Tire, 4.8 - 12, LRC.
A 4.8" tire has a nominal section width of only 122 mm, but an actual width of as much as 135 mm... if you could get a 135/85R15 tire (which you can't, although you could get close to the size with an unsuitable space-saver spare intended only for temporary use), I believe that the 15" setup would have smoother ride, higher load capacity, and less rolling resistance. You would have to find an unusually narrow 15" wheel in a trailer hub pattern and offset, or use an adapter of some sort.
In a quick search, the narrowest 15" tires I could find in North America from tire companies was a Bridgestone Blizzak LM-18 145/65R15 (a winter tire for passenger cars, Euro-sized). Due to the relatively low profile, it's less than two inches taller overall than the 4.80-12. Among other brands, the Michelin X-Ice 175/65R15 was next narrowest (again only a winter). I suspect either of these would roll pretty nicely, but the ribbing from other trailer owners about the winter treads might be hard to take.
The Smart ForTwo uses a 155/60R15 on the front, which would probably be a really nice trailer tire... although I don't know where you buy those tires other than as the Bridgestone Blizzak (Goodyear, Michelin, Continental... none list the size). The Smart wheels fit a three-bolt hub.
In Europe, Continental has the ContiEcoContact 3 in a 135/70R15, which sounds like a nice small trailer size... but only in Europe.
brian_bp
Images: 9
Postby BPFox » Mon Jul 07, 2008 7:53 pm
A buddy of mine used to have a 1962 Chevy Impala. For effect he put a set of 15" Mag Wheels in front that were only 4" wide. Skinny tires up front were all the rage back then. Made your car look like the cars down at the drag stip. I'll bet a set of those would do the thick. :lol:
BPFox
Postby brian_bp » Thu Jul 10, 2008 1:20 pm
BPFox wrote:A buddy of mine used to have a 1962 Chevy Impala. For effect he put a set of 15" Mag Wheels in front that were only 4" wide. Skinny tires up front were all the rage back then. Made your car look like the cars down at the drag strip. I'll bet a set of those would do the thick. :lol:
That could actually work... Centerline 15" narrow drag-style wheels
brian_bp
Images: 9
Postby Bill_Storey » Fri Jul 11, 2008 8:51 am
OK folks. I was on the road on a borrowed computer and connection when I posted this question. The Tractor Supply 4x8 no floor has about 3 inches clearance between the frame rails and the stock 4.80 x 12 tire (5 lug, 4.5 in bolt pattern). I'm guessing the stock rim is 4 inches wide. The rims I bought (unused but 2nd hand) are 5 inches wide. I'm guessing 215-75r-15 mounted on these rims should leave me about 1 - 1.25 inches clearance per side and I was just wondering if anyone else had already mounted 15 inch tires and could confirm the clearance.
The reason I want to do this is 90% looks, 5% increased ground clearance, 3% pothole resistance, 1% bearing speed, and 1% increased increased weight capacity.
Bill_Storey
Postby toypusher » Fri Jul 11, 2008 9:47 am
Bill_Storey wrote:OK folks. I was on the road on a borrowed computer and connection when I posted this question. The Tractor Supply 4x8 no floor has about 3 inches clearance between the frame rails and the stock 4.80 x 12 tire (5 lug, 4.5 in bolt pattern). I'm guessing the stock rim is 4 inches wide. The rims I bought (unused but 2nd hand) are 5 inches wide. I'm guessing 215-75r-15 mounted on these rims should leave me about 1 - 1.25 inches clearance per side and I was just wondering if anyone else had already mounted 15 inch tires and could confirm the clearance.
You know that the clearance that you end up with will depend on the offset of the wheels that you have???
toypusher
Images: 324
Postby Bill_Storey » Fri Jul 11, 2008 10:00 am
Kerry, I was told they are 0 offset wheels, trailer wheels bought from Southwest Wheel.
Bill_Storey
Postby angib » Fri Jul 11, 2008 10:59 am
The 4.80x12 tyres will be about 5.1" wide (you would think they would be 4.8", wouldn't you?) and 215 tyres will be about 8.5" wide so, if both size wheels are zero offset, the bigger tyres will 1.7" wider each side.
This makes your reduction in clearance from about 3" to a little over 1" sound just right.
Andrew
angib
5000 Club
5000 Club
Images: 231
