madjack wrote:#4...less rolling resistance
Certainly true when you compare 15 inch tires with the recommended 30 PSI in them with the 12 inch tires running the recommended 80 PSIangib wrote:madjack wrote:#4...less rolling resistance
I think you'd be shocked by how much more rolling resistance larger tyres have.
Alphacarina wrote:Certainly true when you compare 15 inch tires with the recommended 30 PSI in them with the 12 inch tires running the recommended 80 PSIangib wrote:madjack wrote:#4...less rolling resistance
No question which one is easier to roll
Don
madjack wrote:....wattabout the "gyroscopic flywheel" effect kicking in once the tires ARE rolling
BPFox wrote:A buddy of mine used to have a 1962 Chevy Impala. For effect he put a set of 15" Mag Wheels in front that were only 4" wide. Skinny tires up front were all the rage back then. Made your car look like the cars down at the drag strip. I'll bet a set of those would do the thick.
Bill_Storey wrote:OK folks. I was on the road on a borrowed computer and connection when I posted this question. The Tractor Supply 4x8 no floor has about 3 inches clearance between the frame rails and the stock 4.80 x 12 tire (5 lug, 4.5 in bolt pattern). I'm guessing the stock rim is 4 inches wide. The rims I bought (unused but 2nd hand) are 5 inches wide. I'm guessing 215-75r-15 mounted on these rims should leave me about 1 - 1.25 inches clearance per side and I was just wondering if anyone else had already mounted 15 inch tires and could confirm the clearance.
The reason I want to do this is 90% looks, 5% increased ground clearance, 3% pothole resistance, 1% bearing speed, and 1% increased increased weight capacity.
