Tear Drop trailers average tongue weight?
Postby SuperTroll » Tue Jul 08, 2008 8:42 pm
Now I know there are huge variations due to size, shape, construction, axle placement, yada yada ad nauseum , but can you define a range that the majority of Teardrops would likely fall within?
just curious.....
Keep thinking outside the box and all manner of ideas will become reality......
http://home-and-garden.webshots.com/alb ... Ul?start=0
SuperTroll
Postby G-force » Tue Jul 08, 2008 9:57 pm
I would say 75 to 150 pounds considering the majority of tears are in the 750-1500 pound range and you are shooting for 10% of the weight on the ball.
Mike
G-force
Images: 22
Postby SlyTerry » Tue Aug 05, 2008 6:10 pm
I think 15% of the gross trailer weight would be the minimum tonque weight I would have especially with light tow vehicles. My 2 cents.
Terry
SlyTerry
Images: 21
Postby KevinS » Tue Aug 05, 2008 6:58 pm
SlyTerry wrote:I think 15% of the gross trailer weight would be the minimum tonque weight I would have especially with light tow vehicles. My 2 cents.
Terry
That means my Corolla with it's max. tonque weight of 75# can only tow a 500# teardrop.
:thinking:
KevinS
Images: 9
Postby madjack » Tue Aug 05, 2008 7:21 pm
American standards for tongue weights favor 10% of total...over in Yurp, they go lighter(but then they are Yurpeens)
Postby Steve F » Tue Aug 05, 2008 7:45 pm
Mine is 13% at the moment but doesn't have the battery in the back or tongue box yet, I'd expect it to finish around the same mark though.
Cheers
Steve F
Images: 25
Postby SlyTerry » Wed Aug 06, 2008 6:53 pm
Kevin I use to have a 7500 lb. boat on a twin axle trailer that only had a tongue weight of 115 lbs would you like to pull that with your Corolla? In my experience most creatures in nature do not have tails exceeding their body weight :shock: and live for long. Tongue weight is not an absolute but a variable to consider when designing or towing trailers. As for my boat and trailer, it would overwhelm my 6500 lb Suburban when things got dicey and although the manual said 10,000 lb towing capacity my gut said this ain't fun no mo! I think my 2 cents are up. :applause:
SlyTerry
Images: 21
