Searched about it, but found only "stuck" ones.....
And, a possibility to keep moisture/dust/water out of the tearwith the drop floor?
Karl Stevens wrote:...What about a removable box with a lip around the top edge that fits in a frame in the floor. When traveling, the box would be upside down, .... When in use, you flip it over so it hangs below the floor level.
For that matter, the box would not need to be upside down when traveling. It could just rest on the sheet and also serve as a container for loose items.
jimqpublic wrote:http://iowaboys.com/2147/2147.htm
I saw ................. including a drop-down floor and drop-down bunk. Some of the photos show part of the mechanism.
