tinksdad wrote:Just an estimated guess; but the axle/spring mounts will probably have to be moved to the rear some to get a better balance ratio.
angib wrote:tinksdad wrote:Just an estimated guess; but the axle/spring mounts will probably have to be moved to the rear some to get a better balance ratio.
Alternatively, chop off the last 'bay' of the frame and put the teardrop body further forwards - it looks like the tongue may be long enough.
Remember the teardrop body is not limited to the 'square' bit of the frame.
Andrew
