I am finishing up my frame and need to add a trailer jack. As you can see in the pic, I have an A-Frame, '46 Kitt that I am basically rebuilding from the wreckage.
Will the Swing-away trailer jacks work on this one? If not what is recommended. The area where the regular a-frame trailer jack was supposed to go was welded up long ago with a heavy duty plate and I don't want to remove this and add another plate for the original jack.
I am not sure if the angle would matter on the A-frame tongue if I get a swing-away jack.
Any thoughts or ideas!
Thanks,
Gabe
