Experienced any problems from too soft springs?
Postby misterW » Mon Feb 22, 2010 2:55 pm
Someone I know suggested getting using overly stiff springs in order to avoid trailer motion when you are moving around inside, sleeping, etc. This certainly runs contrary to how I was thinking about things, but I figured I would ask:
Has anyone run into problems with that sort of thing -- too much motion when the trailer is stationary due to soft springs?
P.S. I am aware that if I should see a teardrop trailer rockin', it is probably not best to knock on the door to inquire as to the cause of the problem...
misterW
Postby doug hodder » Mon Feb 22, 2010 3:45 pm
I'd bet that most people put down stabilizers of some sort, if their planning on camping for more than a quick sleep. I always do. Doug
Postby emiller » Mon Feb 22, 2010 4:36 pm
I use 3500# axle with 2000# springs. You don't want to stiff of a ride or your trailer will bounce all the way down the interstate. Like Doug said use stabilizers for your trailer when parked.
emiller
Images: 157
Postby 48Rob » Mon Feb 22, 2010 7:09 pm
The someone you know may mean well, but is incorrect in the belief that vanity is more important than a trailer that will tow comfortably, and safely down the highway.
As the others have suggested, stabilizers will stop your campground neighbors from knowing just what you are doing inside... ;) unless you're really noisy :oops:
Good for you for asking!
Sometimes friends offer advice that is taken when it should not be... :thinking:
Rob
48Rob
