Newman39Fan wrote:I started putting my frame together and ran into my first of many to come glitches. I assumed, I really need to stop assuming, that the 2 center supports would just slide into the main frame and the holes would line up. However it appears that they only line up on one side, the front, and I need to drill holes in the rear section to attach them. Is this correct or am I doing something wrong? I tried moving the supports that are in the middle of the front and rear back one notch, but then you lose 2 of the 3 original bolt contacts. This seems less rigid for the build?
Anyway does anyone have advice, or step by step instructions on how to convert this folding trailer into a rigid trailer? I will await your response with a beer and a smoke. Then again this might help me figure it out on my own!
