HF 90154 rigid assembly instructions needed
Postby Newman39Fan » Sat Mar 06, 2010 5:00 pm
I started putting my frame together and ran into my first of many to come glitches. I assumed, I really need to stop assuming, that the 2 center supports would just slide into the main frame and the holes would line up. However it appears that they only line up on one side, the front, and I need to drill holes in the rear section to attach them. Is this correct or am I doing something wrong? I tried moving the supports that are in the middle of the front and rear back one notch, but then you lose 2 of the 3 original bolt contacts. This seems less rigid for the build?
Anyway does anyone have advice, or step by step instructions on how to convert this folding trailer into a rigid trailer? I will await your response with a beer and a smoke. Then again this might help me figure it out on my own!
Newman39Fan
Postby PaulC » Sat Mar 06, 2010 5:45 pm
Have you had a look at the Generic Benroy plans? I'm thinking it shows how in there.
Cheers
Paul :thumbsup:
PaulC
3rd Teardrop Club
Images: 36
Postby Newman39Fan » Sat Mar 06, 2010 5:56 pm
The Generic Benroy plan uses a Red Trailer, not HF.
Newman39Fan
Postby Juneaudave » Sat Mar 06, 2010 6:12 pm
Do these assembly instructions help?
Harbor Freight 90154 Assembly Instructions
:thinking:
Juneaudave
Images: 380
Postby Newman39Fan » Sat Mar 06, 2010 7:25 pm
Those are the instructions for making it a folding trailer as designed. These do not show how to make it a non-folding rigid trailer
Newman39Fan
Postby steve smoot » Sat Mar 06, 2010 8:26 pm
see if this lead will help you out... :thinking:
http://www.mikenchell.com/zephyr/Teardrop.htm
I am not a complete idiot, some parts are missing...
steve smoot
Images: 62
Postby Newman39Fan » Sun Mar 07, 2010 8:46 am
Yes, that helped in 2 ways. Not only did it help with my cross beam question, but it answered my yet to be asked axle move question.
Thanks for the help
Newman39Fan
Postby steve smoot » Sun Mar 07, 2010 9:02 am
Good, my wife says I'm useless, and tried to tell her that was not totally true... :applause:
steve smoot
Images: 62
Re: HF 90154 rigid assembly instructions needed
Postby nikwax » Sun Mar 07, 2010 7:15 pm
Newman39Fan wrote:I started putting my frame together and ran into my first of many to come glitches. I assumed, I really need to stop assuming, that the 2 center supports would just slide into the main frame and the holes would line up. However it appears that they only line up on one side, the front, and I need to drill holes in the rear section to attach them. Is this correct or am I doing something wrong? I tried moving the supports that are in the middle of the front and rear back one notch, but then you lose 2 of the 3 original bolt contacts. This seems less rigid for the build?
The two halves of the trailer do line up, and you should not need to drill holes in the frame. Which is a good thing, as the frame is hardened steel and not easy to drill holes in (ask me how I know ;-)
nikwax
Images: 30
Postby Newman39Fan » Sun Mar 07, 2010 8:13 pm
I tired every way posible, the best I could come up with was 1 hole lining up. So I am not sure how you got them to line up without having to drill?
Newman39Fan
Postby rainjer » Sun Mar 07, 2010 8:28 pm
If you are try to make a folding trailer ridged, you will need to drill new holes when you insert it into the side rails. You will also need to drill thru them where you spring mount brackets attach.
Jeremy
rainjer
King Koleman
Images: 11
Postby Newman39Fan » Sun Mar 07, 2010 8:54 pm
I do have a new question. I don't have much drilling experience with metla. Am I going to be able to drill these holes with a cordless Dewalt drill? Or am I going to need more beef of a corded drill or a drill press?
Thanks
Newman39Fan
Postby TwilightLane » Sun Mar 07, 2010 11:07 pm
Hey Newman,
Check my build thread, I just figgured this all out last weekend. Drilled quite a few holes. PITA.
Send me a message if you want to talk about it.
http://tnttt.com/viewtopic.php?t=35658
Rob & Lori
Aspen & Tundra
My Instructable: http://www.instructables.com/id/Teardro ... l-Trailer/
TwilightLane
Postby TwilightLane » Sun Mar 07, 2010 11:09 pm
I used a corded dewalt drill, new bit, regular motor oil instead of cutting oil (per rec from ACE hardware guy). Worked fine, took a while. Then dressed the holes w a rat tail file. I discovered that LESS pressure wound up with a cleaner hole and thus less work with the file. YMMV.
Rob & Lori
Aspen & Tundra
TwilightLane
Postby brewwagon » Sun Mar 14, 2010 6:40 pm
I just purchased the folding trailer from HF. I understand about taking the 2 cross pieces and using them to attach the "front" and "rear" sections.
Has anyone done this but extended the total length of the trailer by 6-12 inches?
brewwagon
