Axle Slips in U-Bolts
Postby jeromie » Thu Oct 13, 2011 4:10 pm
I'm having an interesting problem. I've been rebuilding a canned ham, and I replaced the original axle with an axle with brakes installed.
For the record, it's this U-bolt kit and this axle. I tried asking them directly, but they wouldn't write me back. :)
The problem I'm running into is that when I brake, the wheels stop, but the axle spins in the U-bolts. Not a lot, but enough to wrap the wiring around the axle and disconnect it the first time I brake hard.
I'm not sure if this is a situation where I simply need to apply more torque, or if I made a fundamental installation mistake.
jeromie
Postby Sonoma ZR2 » Thu Oct 13, 2011 4:37 pm
It looks as if the spring perches aren't welded to the axle to keep it from giving you axle wrap.
Sonoma ZR2
Images: 90
Postby eamarquardt » Thu Oct 13, 2011 5:11 pm
Sonoma ZR2 wrote:It looks as if the spring perches aren't welded to the axle to keep it from giving you axle wrap.
Yup. They need to be welded to the axles.
Gus
eamarquardt
Images: 150
Postby Dale M. » Thu Oct 13, 2011 5:46 pm
Ditto with above two posts....
Loosen up u-bolts and realign axle to where it is supposed to be, and go by a welding shop and have them run a bead joining bracket to axle tube...
Dale
Dale M.
Images: 18
Postby starleen2 » Thu Oct 13, 2011 7:11 pm
Saw the same thing too - weld em' up and you'll be fine to go
starleen2
5th Teardrop Club
Awesome!
Postby jeromie » Thu Oct 13, 2011 8:25 pm
Thanks! I figured I did something dumb. :)
jeromie
Re: Awesome!
Postby eamarquardt » Thu Oct 13, 2011 9:18 pm
jeromie wrote:Thanks! I figured I did something dumb. :)
Not in my book as you installed brakes.
Gus
eamarquardt
Images: 150
