HF trailer with 8in wheels - floor clearance
Postby jonwwo » Tue Jun 19, 2012 3:44 pm
Looking at the HF 950 LB Capacity Trailer, it seems that a slightly raised floor would clear the wheels without the need for an uneven floor (no wheel cut outs with a wider than 4' cabin).
http://www.harborfreight.com/950-lb-capacity-foldable-4-ft-x-8-ft-utility-trailer-with-8-inch-wheels-and-tires-42709.html
Is this assumption true and would these small 8 inch wheels be sufficient to take on long road trips? Im planning on a light and simple trailer. No galley, painted sides, ect.
jonwwo
Images: 6
Re: HF trailer with 8in wheels - floor clearance
Postby Oldragbaggers » Tue Jun 19, 2012 8:22 pm
Do you already have the trailer? If not, why not go a little bit more $$ and get the 1760# with 12" wheels and have no worries?
Life is sooooo good.........
Sail...camp....bike...repeat
Becky
Oldragbaggers
Images: 331
Postby absolutsnwbrdr » Tue Jun 19, 2012 9:33 pm
You might be able to get away with 2x2 framing, but it could be close. I used the "heavy duty" HF trailer with 12" wheels and built my floor up using 2x4's. Havent had any issues with rubbing, and I just got back from a trip that consisted of 10 miles of rutted out dirt forest service roads.
The lower section in the rear is for the galley.
Zach
Coming Soon...
absolutsnwbrdr
Images: 412
Postby Oldragbaggers » Tue Jun 19, 2012 10:00 pm
Actually Zach, I think it's the added height of the beer bottles that made things work out so well for you!
Becky
Oldragbaggers
Images: 331
Postby bobhenry » Wed Jun 20, 2012 5:31 am
It take a fuzz over 4" to clear the fenders.
Postby jeff0520 » Wed Jun 20, 2012 6:24 am
I'm using the HF 1920 lb trailer with 12 " wheels. I answered that question by measuring the clearance between the axle and the frame, and calling that my maximum suspension travel. I built the floor framing, and measured the clearance between the top of the tire and the top of the frame. I discovered that the tire could potentially rub the floor if the suspension bottomed out. I ended up building a 1 inch tall raised wheel well. I'd rather have had a flat floor, but I'd MUCH rather know for certain I'm not going to have an issue with tires rubbing. :)
Hypno-Toad's Command Post, the build thread! http://www.tnttt.com/viewtopic.php?f=50&t=50384
jeff0520
Images: 128
Postby 48Rob » Wed Jun 20, 2012 6:25 am
I don't own a red trailer and so don't know if they come with slipper springs...if they do then please disregard...
If you have shackles attaching the leaf spring to the rear spring hangers, you can install longer shackles and reduce the amount of build up height you need to clear the fenders.
2" longer shackles will get you 1" of trailer height.
Rob
48Rob
Postby len19070 » Wed Jun 20, 2012 4:34 pm
I did it with the 12" tire's.
Happy Trails
Len
len19070
Images: 24
Postby Tabazooron » Thu Jun 28, 2012 7:59 am
Is the speed rating different for the 8" & 12" wheels?
Ron H
Great Lakes Chapter of TearJerkers
Tabazooron
Postby synaps3 » Wed Jul 11, 2012 8:04 am
Tabazooron wrote:Is the speed rating different for the 8" & 12" wheels?
Both tell you not to exceed 55mph on the rims. :lol: I'd imagine the 12" wheels are more forgiving though.
My utility trailer is on a HF frame with 12" wheels, it's been up to 90mph before, while hauling about 1000lbs of dirt bike and gear. It's got easily 10k miles on it, at least 3/4 of those over 55mph with no issue. I carry a spare just in case though. :thumbsup:
-- Dave
Build log: here
synaps3
Images: 254
