Timbren axle-less suspension
Postby Kanguru » Tue Oct 09, 2012 8:10 am
These seem like an easy option for a frame build. http://www.etrailer.com/Trailer-Suspens ... RS545.html Has anyone actually used them?
Kanguru
Re: Timbren axle-less suspension
Postby Oldragbaggers » Tue Oct 09, 2012 8:51 am
And I imagine would reduce weight quite a bit as well.
Life is sooooo good.........
Sail...camp....bike...repeat
Becky
Oldragbaggers
Images: 331
Postby Lgboro » Tue Oct 09, 2012 1:34 pm
Wouldn't you still have to attach your tongue to this set up similar to Andrew's ultra light chassis? Even if not it would require some really strong wood which might weigh more than the torsion axle used in the ultra light chassis plan.
Lgboro
Images: 53
Postby alaska teardrop » Tue Oct 09, 2012 2:26 pm
    Kanguru, Thanks for the link. Those units would be usefull for building a really low riding teardrop by designing a chassis where the axles are mounted somewhere above the floor framing. Other than that, I don't see any advantage over a #8 Dexter axle. Alignment is more complicated, they cost more, they are heavier than a Dexter and they require more strength (weight) at the attachment points.
    :peace: Fred
alaska teardrop
Postby droid_ca » Tue Oct 09, 2012 3:19 pm
I'm looking at a little garden trailer utility frame and was thinking of swapping out the axles I wonder if this one will work for what I'm considering....Thanks for sharing it I bookmarked it
“Fide Canem”
viewtopic.php?f=5&t=52816
droid_ca
Images: 176
Postby Kanguru » Wed Oct 10, 2012 6:16 am
Hmmm...Dexter is less expensive. I had not checked on that. Plus I understand you can get Dexter with differend drops as well. Hope this will be helpful to someone.
Kanguru
Postby Kanguru » Wed Oct 10, 2012 6:20 am
Lgboro wrote:Wouldn't you still have to attach your tongue to this set up similar to Andrew's ultra light chassis? Even if not it would require some really strong wood which might weigh more than the torsion axle used in the ultra light chassis plan.
Absolutely! I was not advocating elimination of quality metal frame construction.
Kanguru
