air bag suspension
air bag suspension
Postby del » Fri Feb 01, 2013 11:53 pm
Would like thoughts on using this instead of springs.
http://www.ebay.com/itm/200825876223?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1438.l2649
Thoughts on the suspension links and joints.
Would like to lower the trailer when parked for better access.
del
del
5000 Club
5000 Club
Images: 410
Re: air bag suspension
Postby Dale M. » Sat Feb 02, 2013 11:00 am
There was a thread about using air bags a year or two ago.... Yes it can be done, and its probably not that complicated...
You might try "search" feature to see if scribblings on air bags is still viable, or available...
The lowering idea while parked seem like a pretty good idea.... My vertically challenged wife would like that...
Here is what quick search for "air bag" turned up...
viewtopic.php?f=35&t=52076&p=957909&hilit=air+bag#p957909
Dale
Dale M.
Images: 18
Postby del » Mon Jul 08, 2013 8:03 pm
bump
del
5000 Club
5000 Club
Images: 410
Postby 48Rob » Tue Jul 09, 2013 6:06 am
Del,
I started one a year or so ago, but had to put it on hold until we get our daughter and grandchildren on their feet.
Hope to get back at it soon.
Rob
48Rob
Postby mezmo » Wed Jul 10, 2013 10:47 pm
Del,
Maybe this could be adapted for your situation -
[just don't do the swivel aspect.]
http://www.powerstroke.org/forum/fabric ... ailer.html
Norm/mezmo
mezmo
Images: 194
Postby 48Rob » Thu Jul 11, 2013 6:34 am
Pretty inovative! :thumbsup:
Thanks for posting that Norm.
48Rob
Postby angib » Thu Jul 11, 2013 3:53 pm
I must say those two-into-one arrangements for non-steering trailers worry me. There's a lot more going on than a regular receiver.
In this example it's probably a Class III receiver with a trailer carrying only 1500 lbs, so no problem, but it's not a design I would like to see copied. Drive the truck-trailer over an angled dip so the truck is rolling right and the trailer wants to roll left and there is suddenly a big torque applied to something that normally has a ball coupler, so zero torque.
angib
5000 Club
5000 Club
Images: 231
Postby KCStudly » Thu Jul 11, 2013 11:15 pm
angib wrote:I must say those two-into-one arrangements for non-steering trailers worry me.
+1, and as always, the correct engineering analysis. As soon as you spread that load path out to the corners the leverage skyrockets. And swivel casters just aren't intended for high speeds or the kind of shock loading seen in highway use.
There's a reason they stopped doing it this way, me thinks.
Postby Corwin C » Sun Jul 14, 2013 3:49 pm
KCStudly wrote:+1, and as always, the correct engineering analysis. As soon as you spread that load path out to the corners the leverage skyrockets. And swivel casters just aren't intended for high speeds or the kind of shock loading seen in highway use.
Not only that, but when cornering, the casters are going to tend to tuck under rather than assist with the lateral load ... with that elongated center of gravity, it's placing severe torque on that hitch in the yaw axis during regular highway travel. I wonder if a ATV/UTV is heavy enough to make a pickup "switch ends" in less than ideal traction conditions? I believe this is the reason why the single wheel caster trailers never became popular. Crack the whip anyone? Perhaps a "braided" skid mark?
Corwin
Image Image Image
-- myself
Corwin C
Images: 78
Postby 48Rob » Sun Jul 14, 2013 4:26 pm
Okay...
So it is a poor design, and not safe.
I still think it was innovative using off the shelf parts.
Rob
48Rob
Postby KCStudly » Sun Jul 14, 2013 7:24 pm
Innovative like those early pioneers trying to fly that crashed and burned off of the cliff: yes. I'll give you that. :o
Postby mezmo » Mon Jul 15, 2013 12:00 am
I posted that link for the wheel suspension - as a possible approach.
I agree with/on the objections to the double-hitch-into-one-receiver
set-up. I've always thought that dual hitch attachment was necessary
for the single wheel or swivel wheel type trailers. So why not use dual
receivers for them now-a-days, since bumper hitches are a thing of the
past ? Swivel wheels have their place. It's like anything - you just
need to apply some common sense to the situation at the minimum.
Here's some links for independent air suspension [most from 'down under'],
and maybe a couple other suspension approaches, that I came across:
http://www.airrideequipment.com/
http://www.bushtrackerforum.com/viewtop ... cfa90af582
http://www.youtube.com/watch?v=PEPfCfeK8Ok
http://www.travelander.com.au/about-us/ ... uspension-
http://www.travelander.com.au/images/st ... Spring.pdf
http://www.trakmaster.com.au/Off-Road-C ... nsion.aspx
http://www.thetrailershop.com.au/SIMPLI ... 15894.html
http://www.gnschassis.com.au/products_suspension.html
Norm/mezmo
mezmo
Images: 194
Postby Bogo » Mon Jul 15, 2013 4:51 pm
KCStudly wrote:
angib wrote:There's a reason they stopped doing it this way, me thinks.
I hate them on my hay rake. They will catch a grove, and try to steer the rest of the rake. At speed on the road they will vibrate all over the place unless I tighten down their vibration brakes allot. Yes, they have a disc brake on the swivel axis.
Bogo
Images: 39
Postby Shadow Catcher » Mon Jul 15, 2013 5:16 pm
Were I interested in a truly off road tear I would be using the AT trailer design. This is one of the best discussions on suspensions I have found http://www.adventuretrailers.com/suspension.html#rubber
Postby del » Mon Jul 15, 2013 6:05 pm
Crazy me just wants to see pics of how people hooked up the suspension with airbags.
del
5000 Club
5000 Club
Images: 410
