angib wrote:I must say those two-into-one arrangements for non-steering trailers worry me.
KCStudly wrote:+1, and as always, the correct engineering analysis. As soon as you spread that load path out to the corners the leverage skyrockets. And swivel casters just aren't intended for high speeds or the kind of shock loading seen in highway use.
There's a reason they stopped doing it this way, me thinks.
Not only that, but when cornering, the casters are going to tend to tuck under rather than assist with the lateral load ... with that elongated center of gravity, it's placing severe torque on that hitch in the yaw axis during regular highway travel. I wonder if a ATV/UTV is heavy enough to make a pickup "switch ends" in less than ideal traction conditions? I believe this is the reason why the single wheel caster trailers never became popular. Crack the whip anyone? Perhaps a "braided" skid mark?
