doug hodder wrote:I've built a number of axles without any camber in them using square tube and spindle stubs. One thing I've done is drill a large hole on the end of the axle side and then plug weld the stub once it's in position as well as the outer edge of the tubing to the stub. FWIW. Doug
Willowagon wrote:Success on the axle! It tows straight as an arrow. I was able to get the stubs square no problem and I employed Doug's idea of drilling a hole in the axle where the stub ends so I could get a bead on it for extra peace of mind. Yes, I know there are prefabbed replacement axles out there for around the same $$ I spent on building my own, but none of the prefabbed ones fit my needs. No manufacturer I found makes an axle thatwould provide me with 58-1/4" hub face to hub face, so I would be sticking out too far or have to do heavy mods narrowing or widening a new axle to make it work. Plus, the spindles came with hubs/bearings preinstalled with marine grade grease and quik lube fittings, so no messing with re-using my old hubs and bearings. If you need a custom width axle and have the abiltiy to weld, its an easy project
Willowagon wrote:Its not really clearance/tolerance, but I have narrow fenders and I wanted to get those wheels dead center so I didn't have to re-work my fender brackets. I liked being able to mock everything up before making final cuts & welds.
I weigh in about 850-900 lbs dry, add 200-300 with gear, firewood, full water tanks & loaded cooler. My 4 banger Volvo wagon pulls it just fine, a little underpowered when climbing hills (Conejo Grade is a bummer), but I have 4 wheel discs and a manual transmission so I can stop it on a dime if necessary.
