Anyone built their own axle?
Postby Willowagon » Thu Feb 28, 2013 4:05 pm
Hi guys, I finally got around to my bent axle replacement project and decided to order the cut-to-length 1.5" square axle tube & weld-in spindles from Northern Tool. Has anyone here used this kit before or built thier own axle from scratch? I'm wondering if I have to worry about wheel alignment in terms of toe-in & camber. As far as I can tell the axle they sent me is just a straight piece of square tube steel. I dont think there is any bow in it for camber and the limited instructions don't say anything about toe-in wheel alignment. Is this even necessary on an 800lb trailer?
Willowagon
Images: 16
Re: Anyone built their own axle?
Postby KCStudly » Thu Feb 28, 2013 5:11 pm
The fact that you are contemplating making your own axle presumes that you are (or have the help of) a competent welder (both the person and the machine). I would not recommend the following if that is not the case.
One opinion (mine) is no, you don’t need camber for small light trailers; build it as straight as you can and if there is a little toe due to welding, put the ‘toe in’ at the front.
I would try to avoid uneven camber (could get uneven tire wear... or even worse, quirky handling such as wag). If you get everything lined up straight (clamp it if you can) and just tack weld the four centers of the spindle spuds in the middle of the flats on the square stock first (one tack at a time starting on one pair of opposite sides, making any needed adjustments along the way) you should be able to make small adjustments and pull it right straight where you want it by adding weld in small equal proportions.
Use the same sequence and jump back and forth from one spindle to the other giving each time to cool between welds so nothing moves with too much exuberance. The worst thing to do would be to rush and burn it all in all at once and then find that it pulled all over the place and is no longer straight.
If it bugs you, there are ways that you can put some camber in. I would use one of the following methods on the tube before adding the spindles.
Heat and form method:
Tack weld a few angle iron locating lugs to the welding bench (two on the left and two on the right) all facing the edge of the bench aligned in a row, but far enough back from the edge to allow the axle to be clamped down. Weld a spacer in the middle to set the amount of camber desired (maybe a piece of 1/2 inch square stock welded to the bench), then clamp one end of the axle tube down with the middle on the spacer and one end on the bench. Clamp that side of the axle face to the two lugs on the same side. Heat the center of the top, front and rear sides to orange hot and draw it down to the bench and lugs with clamps locking in the camber. That way you don't accidentally put twist or bend it in the wrong plane.
Another way would be to bump it in a hydraulic press, but you would need to be sure not to crease or crush it.
A small slit on three sides (front, rear and bottom) from a cut off wheel to form a miniature pie cut, bevel the edges, bend to close the notch, weld, then scab on some flat bar fish plate reinforcements would work, too. Taper the ends of the fish plates into diamond shapes so that you do not introduce a single line stress point.
Just my ramblings on the subject.
Postby doug hodder » Thu Feb 28, 2013 9:14 pm
I've built a number of axles without any camber in them using square tube and spindle stubs. One thing I've done is drill a large hole on the end of the axle side and then plug weld the stub once it's in position as well as the outer edge of the tubing to the stub. FWIW. Doug
Postby KCStudly » Thu Feb 28, 2013 9:20 pm
+1 what Doug said.
That will add a lot of strength by spreading the anchor points that way. Sort of a form of triangulation, helping to anchor the spindle to the tube in more than one line or plane of force.
Good call. :thumbsup:
Postby Dale M. » Thu Feb 28, 2013 9:58 pm
doug hodder wrote:I've built a number of axles without any camber in them using square tube and spindle stubs. One thing I've done is drill a large hole on the end of the axle side and then plug weld the stub once it's in position as well as the outer edge of the tubing to the stub. FWIW. Doug
Ditto.... IF you have quality spindles (manufactured on center) and the right fit into tube there is not really any problems.... Everything sort of lines up by default.... Welding is main issue..... A couple of good plug or rosette welds and a bead with good penetration around tube/spindle seam and life is good.... Its a lot easier (simpler)than some would like to admit.... Measuring is the toughest thing and getting spring indexing holes located correctly is a must....
Dale
Dale M.
Images: 18
Postby CarlLaFong » Fri Mar 01, 2013 12:10 am
The AMC/Rambler spindles are a natural for building your own axle. They're probably getting a bit hard to find, though.
http://jkcallin.blogspot.com/
CarlLaFong
Images: 5
Postby Dale M. » Fri Mar 01, 2013 9:55 am
Actually some of the newer cars has almost same concept..... My Chevy PU has a spindle/bearing/hub assembly held on by 3 bolts..... It all has to be replaced, you can not break it down and repack wheel bearings anymore, its all pressed together as a unit....
Dale
Dale M.
Images: 18
Postby Willowagon » Fri Mar 01, 2013 3:54 pm
Cool, thanks for the responses. I have never welded critical components like this before, but I have a decent mig welder and can lay some pretty good looking fillets. I'm confident they will be more than adequate. My only other issue is that the spindle stubs don't fit 100% tight into the axle ends, they probably have about 1/32" of wiggle, which i don't really like, but i'm sure I can get them 99.9% centred in the tubes. I will be drilling that hole so I can weld the end of the stub, good suggestion! I'll post some pics when i'm done
Willowagon
Images: 16
Postby H.A. » Fri Mar 01, 2013 9:03 pm
[q
H.A.
Postby eamarquardt » Sat Mar 02, 2013 3:33 am
A 3,500# axle is about $120. i just don't see the "economy" of going to the trouble to buy the components and weld it up yourself. Also, unless your spindles come with the flanges to mount brakes on, adding the flanges adds another level of complexity to the task.
Now if you have all the time in the world, all of the tools required, and are a really good scrounge you can probably build anything for next to nothing. However, if can use your time to generate income you might be time/money ahead to work, earn the money required, and just buy the axle.
http://www.trailerpartsdepot.com/items. ... =0&Tp=&Bc=
More "World according to Gus".
Alternately you can do it because you wanna weld up your own axle for the experience of doing so.
Cheers,
Gus
eamarquardt
Images: 150
Postby KCStudly » Sat Mar 02, 2013 11:01 am
Postby Willowagon » Tue Mar 05, 2013 3:24 pm
Success on the axle! It tows straight as an arrow. I was able to get the stubs square no problem and I employed Doug's idea of drilling a hole in the axle where the stub ends so I could get a bead on it for extra peace of mind. Yes, I know there are prefabbed replacement axles out there for around the same $$ I spent on building my own, but none of the prefabbed ones fit my needs. No manufacturer I found makes an axle thatwould provide me with 58-1/4" hub face to hub face, so I would be sticking out too far or have to do heavy mods narrowing or widening a new axle to make it work. Plus, the spindles came with hubs/bearings preinstalled with marine grade grease and quik lube fittings, so no messing with re-using my old hubs and bearings. If you need a custom width axle and have the abiltiy to weld, its an easy project
Willowagon
Images: 16
Postby eamarquardt » Tue Mar 05, 2013 3:35 pm
Willowagon wrote:Success on the axle! It tows straight as an arrow. I was able to get the stubs square no problem and I employed Doug's idea of drilling a hole in the axle where the stub ends so I could get a bead on it for extra peace of mind. Yes, I know there are prefabbed replacement axles out there for around the same $$ I spent on building my own, but none of the prefabbed ones fit my needs. No manufacturer I found makes an axle thatwould provide me with 58-1/4" hub face to hub face, so I would be sticking out too far or have to do heavy mods narrowing or widening a new axle to make it work. Plus, the spindles came with hubs/bearings preinstalled with marine grade grease and quik lube fittings, so no messing with re-using my old hubs and bearings. If you need a custom width axle and have the abiltiy to weld, its an easy project
Glad it worked out. Every time I've ordered an axle it has been "made to order". They seem to be willing to make them in inch increments. If yours has to be within 1/8" on each side to work your tolerances/clearances are a heck of a lot tighter/closer than I'd feel comfortable with.
How much will your trailer weigh, what are you towing with, and have you considered brakes?
Cheers,
Gus
eamarquardt
Images: 150
Postby Willowagon » Wed Mar 06, 2013 11:32 am
Its not really clearance/tolerance, but I have narrow fenders and I wanted to get those wheels dead center so I didn't have to re-work my fender brackets. I liked being able to mock everything up before making final cuts & welds.
I weigh in about 850-900 lbs dry, add 200-300 with gear, firewood, full water tanks & loaded cooler. My 4 banger Volvo wagon pulls it just fine, a little underpowered when climbing hills (Conejo Grade is a bummer), but I have 4 wheel discs and a manual transmission so I can stop it on a dime if necessary.
Willowagon
Images: 16
Postby eamarquardt » Wed Mar 06, 2013 11:48 am
Willowagon wrote:Its not really clearance/tolerance, but I have narrow fenders and I wanted to get those wheels dead center so I didn't have to re-work my fender brackets. I liked being able to mock everything up before making final cuts & welds.
Just what is this "Conejo Grade" you speak of. If you take the 118 (and suffer through the Somis stoplight which never seems to be green when I get there) you don't have to deal with the grade.
Just for grins I'd weigh your trailer when it's fully loaded. I once owned a 38' sloop. It kept riding lower and lower in the water but I knew there was no leak as I installed a zerk fitting in the stuffing box, pumped it full of grease, eliminated the drip, drip, drip, and had nothing but dust in the bilge. Anyway, when unloaded all the stuff I'd dragged oboard over the years, it returned to its original waterline. I was stunned as to how much I'd snuck aboard over the years.
I believe in brakes, brakes, and more brakes. My utility/dump trailer has electric and hydraulic brakes. Fully separate and redundant systems. If I'm towing 5,000# I want to stop under all circumstances. And yes, the master cylinder on the trailer went out after about 10 years and the hydraulic brakes didn't work (and I hadn't connected the electrics yet) and we noticed the difference. I'd be willing to bet that if you look at the ratings of your vehicle that, even as light as your trailer is, that your over the weight your brakes were designed to stop. I once came down from Big Bear Lake towing a 1,400 tent trailer w/o brakes. I was driving a Ford Taurus wagon (maybe bigger brakes than your Volvo, maybe not) and nearly didn't get down the hill alive. Won't do that again. EVER!!!!!!
I"m in Simi. Gimme a shout.
Cheers,
Gus
eamarquardt
Images: 150
