GuitarPhotog wrote:Hmmm, then why does the Model A guy sell just what I showed in the pix? And why was there no evidence of a loose outer race in the hub/brake drum when I removed it?
He does sell the outer races here
http://www.modelaparts.com/products/769-a1202.aspx and here
http://www.modelaparts.com/products/790-a1217.aspx, but if I were you I would support a fellow TNTTTer and get what you need from Nevadatear.
The thing you are missing is that Timken sells "cups" (outer bearing races) and "cones" (inner bearing races with caged roller bearings) separately. Sometimes you can get them as sets, and sometimes they come in kits as sets, but not always. They sell them individually so that the same outer race can be used with cones that have different inside diameters (and perhaps vice versa), suiting various applications.
Don't be confused by Tam's reference to "inner" and "outer"; they are referring to the spindle location that the bearing fits (inside at the grease seal, or outside at the spindle nut). I am referring to the bearing set and which piece goes where with regard to each other and the spindle OD (inner race) and hub bore ID (outer race).
You probably didn't notice that the outer race is separate because they are usually pressed into their bores in the hubs with an interference fit and do not usually separate easily (unless they have spun and worn their bore out). If you didn't wipe all of the grease out thoroughly and really look closely where the bearing fits into the bore, you may not have noticed that they are in fact separate pieces.
For some one who does not have the tools or know the proper technique to remove an outer race from the hub it could be very tempting to just put a new cone bearing into the old race, but do NOT do this. It will not last long at all. Once a bearing and race have run together they have become intimate, akin to lapping in a valve, and should not be swapped around.
If you do not have the ability to properly remove and reinstall the races in the hub bores, you can have this done at most automotive parts stores or machine shops for a small fee. You can use a brass punch to remove them (there is usually a small "window" in the casting on the back side of the race where you can get a punch in there to remove), but you definitely DO NOT want to use a punch to put the new ones in. A bearing installation tool or an old race ground down on the outside can be used to press the new races in.
I hope that I have not presumed too much and that this helps clear things up for you.
