Shock mounts?
Shock mounts?
Postby noseoil » Tue Jul 29, 2014 1:07 pm
I've been looking for a shock mount to add to a leaf spring setup. Monroe no longer makes their kit to retro-fit a shock to a leaf spring setup, at least I don't think so and can't find one. Does anyone know of an after-market plate to go with 1 3/4" springs (2" axle, 9/16" u-bolts) for the bottom attachment point on a small shock? Otherwise it looks like I will have to fab some with plates & sleeves. Thanks, tim
137905
noseoil
Images: 670
Re: Shock mounts?
Postby desertmoose » Tue Jul 29, 2014 1:13 pm
I just welded a mount to the axle. (ignore overlength bolt, I got a couple the right length after taking the picture)
Of course, that's assuming you have access to a welder.
Sam
desertmoose
Images: 98
Re: Shock mounts?
Postby noseoil » Tue Jul 29, 2014 1:28 pm
Thanks Moose. I was trying to avoid heating the axle at this point (stress points, change of shape, etc.) and figured the lower spring plate with perch would be best for my needs. I have a buddy who's a good welder, so I guess he can adapt a plate on the bottom of the spring the same way. Just trying to see what's out there & some options....
137905
noseoil
Images: 670
Re: Shock mounts?
Postby KCStudly » Tue Jul 29, 2014 2:28 pm
Here is how I did mine: The Poet Creek Express Shock Absorbers.
Lots of pics and explanations. :thumbsup:
Re: Shock mounts?
Postby noseoil » Tue Jul 29, 2014 7:05 pm
Whoa KC, that's very nice installation! That's a bit more than I was planning on doing, but certainly a nice job. I'll keep snooping for brackets, but it looks like I may end up with a welded spring plate for the job. Can't believe someone doesn't make one I can find easily already, seems like it would be a slam-dunk to sell.
137905
noseoil
Images: 670
Re: Shock mounts?
Postby danlott » Tue Jul 29, 2014 9:28 pm
Here is what I found with a quick search. Not for your size of axle, but may help someone else.
http://www.campingworld.com/search/index.cfm?Ntt=shock+kit&N=0&Ntx=mode+matchallpartial&Ntk=primary&Nty=1&Ntpc=1
Dan
Hoplite Traveler Build thread
danlott
Images: 264
