Bruceaust wrote:I was thinking of using 75mm x 25mm x 2mm RHS for the chassis.
Bruceaust wrote:i reasoned that the higher profile will give a much stiffer structure. I will also use an A frame at the front with triangulated bracing etc. I intend to build a 18mm ply walled Benroy 2.4m x1.5m (8x5)
