Hello northern lower MI
Postby DaveInMI » Wed Oct 07, 2009 7:33 am
I've been lurking a while. Started a generic Benroy, 5x10. The frame is done. I have some 1.5" rigid insulation on hand that I plan to sandwich between luan. I'm not sure how to trim where the hatch and side walls meet when the wall much thicker than the plan. Suggestions?
DaveInMI
Postby dan galvin » Wed Oct 07, 2009 12:15 pm
hello from n/w indiana dave 1.5 in is a little over kill stop your insulation at the rear bluck head no need to insl the galley but insul the bulkhead from the galley side and use some nice vineere 1/2 in to finish the inside of the galley
did that make any sence :? :?
Dan
dan galvin
Images: 43
Postby DaveInMI » Wed Oct 07, 2009 4:53 pm
Thanks for the suggestion. I'm thinking about the transition from 2"wall to .75" wall if that would concentrate any stress on the wall to that line. I've thought of a sort of rabbet joint where a .75" portion of the side wall sticks up the heighth of the hatch.
DaveInMI
Re: Hello northern lower MI
Postby mikeschn » Wed Oct 07, 2009 5:24 pm
DaveInMI wrote:I've been lurking a while. Started a generic Benroy, 5x10. The frame is done. I have some 1.5" rigid insulation on hand that I plan to sandwich between luan. I'm not sure how to trim where the hatch and side walls meet when the wall much thicker than the plan. Suggestions?
Hi Dave,
Welcome to the forum.
You can use 1.5" insulation. And if I lived up there I would probably consider it.
As for trimming where the hatch and the sidewalls meet, use the same method as in the Generic Benroy plans, just let the hatch skin overhang farther.
On page 57 I state that the hatch will be 58" wide. Well, if you are making the walls 2" instead of 1/2", everything will have to be adjusted.
The hatch will be 55" wide instead of 58"
The overhang (see page 59) will be 2 3/4 instead of 1 1/4.
Hope that helps. Holler if you need a quick sketch on a napkin.
Postby DaveInMI » Sat Oct 17, 2009 6:15 am
Thanks, Mike. That sounds doable.
DaveInMI
Postby Karl » Sat Oct 17, 2009 4:14 pm
Dave,
I'm down in the Detroit area. Welcome!
Keep an eye out for Michigan gatherings on the http://tearjerkers.net site.
Karl
Tear Jerkers Director - Great Lakes Chapter
___________________________________________________________________________
Success is getting what you want while happiness is wanting what you get.
Karl
Images: 67
