Using 3/16" Steel sheet panels for walls
Postby Roly Nelson » Thu Mar 25, 2010 9:04 pm
Welcome to the forum, you have come to the right place. However, just to make you feel safer while camping, I have found that my 38 special won't shoot through a sheet of 3/16 sheet steel. Therefore, I have built my 2 rigs out of 3/16 lauan plywood, that probably wouldn't stop a marble fired from a sling shot. Good luck on your build. I sure want to see pics of your progress.
Roly 8) :? :thumbsup:
Roly Nelson
L'il Ol' Woody Builder
Postby nevadatear » Thu Mar 25, 2010 9:41 pm
My husband owns his own machine shop and used to build armored cars (Armored Transport, now Cambli). Even they didn't use 3/16. They used 12 gage. So the 3/16 would be stouter than an Armoured truck! 8) He agrees with Boomboom, his calculations are spot on. So for a tanktear, great idea, but you would also need substantial framing to hold it up and beefed up tires and axel too. Your weight just went from HEAVY to SUPER DOOPER heavy. If you need gun ports or double interlock system for your tanktear, Randy can hook you up. He still manufactures them for Cambli. :lol: :lol: Always exciting to think outside the box! :vroom:
nevadatear
Images: 171
Tin for Skin
Postby Wild Bill » Sun Mar 28, 2010 8:58 pm
Tin for Skin, I think that is a great idea, I have been tossing the idea around myself, Using the tin similar to what furnace installers use when building ductwork for homes, Then the sides would be wood. Would make for a lot of noise on a rainy night. Galvanized would not hold paint but would resist rust, then glue the vinal roofing directly to it. Not sure how the shrinkage rate differences would work. Bill
Beavers are Naughty!
Wild Bill
Images: 63
Re: Using 3/16" Steel sheet panels for walls
Postby unimogdave » Tue Mar 30, 2010 6:00 pm
The M1A1 abrams tank looks good because is has a composite armor. If you are going to use steel of any thickness, plan on having a redish-orange trailer and keep it off the driveway. It will ooze rust from every seam after a year. You can probably find Aluminum in 5x10 panels and it won't rust.
unimogdave
Postby eamarquardt » Tue Mar 30, 2010 7:10 pm
IndyTom wrote::P Welcome Fellow Hoosier :P
So maybe you are planning on some inner-city camping. With 3/16 you would be armored heavily enough for it.
I disagree. You ought to go for at least 3/8" if not 1/2". And don't settle for just plain steel. The high strenght stuff they're using in cars now is much better. Do it RIGHT and you'll never worry about being "ambushed" in the inner cities of our great (and declining) land.
Gus
eamarquardt
Images: 150
Postby Chuckles2153 » Sat Apr 03, 2010 7:05 am
Hey there Mr. Nelson, That's is such a funny response :laughing1: I really got a kick out of it. and i have decided to not go with steel, instead i'm going to build the sandwich style with insulation. I've seen more people use this method than others, I thinking about putting some eastern red cedar on the outside with just a clear coat to bring out the red of the wood.
Chuckles2153
Images: 74
Postby Chuckles2153 » Sat Apr 03, 2010 7:11 am
So maybe you are planning on some inner-city camping. With 3/16 you would be armored heavily enough for it. :laughing1:
Seriously, welcome to the madness, its always great to have more people.
Hey there IndyTom, I don't intend on do any inner city camping but might have to drive through some when i get lost on the way to some of the gatherings when i get it finished. :lol:
Thanks for the response and thanks for the welcome. :D
Chuckles2153
Images: 74
Postby Chuckles2153 » Sat Apr 03, 2010 7:14 am
Gus
I hear that!!
Chuckles2153
Images: 74
Postby ieheg2 » Sat Apr 03, 2010 3:18 pm
Loud will rain pounding on the roof. :DOH2:
Treat people the way you want, that would treat you.
ieheg2
Images: 57
Postby parnold » Sat Apr 03, 2010 5:21 pm
Can you imagine the sound of hail? :?
parnold
Images: 302
The sound of hail!
Postby eamarquardt » Sat Apr 03, 2010 6:38 pm
parnold wrote:Can you imagine the sound of hail? :?
Hail no!
Gus
eamarquardt
Images: 150
Users browsing this forum: tony.latham and 1 guest
