Taking a MIG welding class to begin my build!
Re: Taking a MIG welding class to begin my build!
Postby bobhenry » Mon Oct 15, 2012 1:05 pm
Stacie Tamaki wrote:Thanks for the welcome, link, and advice Bob!
Just read through your entire thread. CUTE trailer! What I found especially intriguing was the smallest trailer you've ever built. Everyone thinks 4' wide is too small. I can't even imagine what they'd think if I went for 3.5' :lol:
Are you speaking of Sadie's dog house or eggbert.
Postby deleted » Mon Oct 15, 2012 1:17 pm
Eggbert! But they're both so cute and tiny.
I'd already decided to build a 2'x4' dog house for my pup just to practice on all of the tools and machines I have to learn how to use to make my trailer. I'll do each step first 1/2 scale and when I've got the preparation and assembly down I'll cut and build mine.
deleted
Images: 85
Postby bc toys » Mon Oct 15, 2012 8:39 pm
you need to look at Roly Nelson page he has a tear no tire just goes in to the hitch :shock: :shock:
bc toys
Images: 42
Postby Vedette » Mon Oct 15, 2012 11:31 pm
If you like your welding class you could forget the "Plywood" all together.
Check out my "Album"
Miles of welding in the building of "Miss Piggy"
Good Roads
Brian & Sandi
viewtopic.php?f=50&t=50912
Vedette
Images: 443
Postby deleted » Wed Oct 17, 2012 2:57 am
I'll go look at the Roly Nelson page right now.
Vedette, I'll go look at Miss Piggy right now too but yeah, I'm definitely leaning towards skipping the exterior plywood and just skinning the foam board. Will probably do a luan for the interior ceiling and interior walls. Or I may still go 1/4" on the interior sidewalls just for more insulation from heat and sound.
deleted
Images: 85
Postby atahoekid » Sat Oct 27, 2012 10:24 am
I think you'll like results you'll get by skinning the foam board!!! I skinned the interior of mine with 5 mm underlayment and the exterior with fiberglass and epoxy. It is quite strong. The underlayment finishes up real nice and the foam board provides great insulation. You can also skin the exterior with canvas using paint as the glue. It really works!! :shock: Check out the Foamie section. We'll be glad to share our knowledge with you :D
Mel
atahoekid
Images: 158
Postby deleted » Sun Oct 28, 2012 4:20 pm
Thanks for the welcome Mel,
At this point I'm planning on using an aluminum skin over blue board. But first I have to find out who sells blue board in or near San Jose, CA. Planning to call the company tomorrow for resellers. Have checked out the Foamie forum a bit but am planning on reading up a lot more in the build threads there.
deleted
Images: 85
Postby atahoekid » Sun Oct 28, 2012 4:30 pm
If you're talking blue board foam insulation, I think Lowes sells it. The pink stuff is sold at HD. The problem you might find is that the thickness you want may not be available depending where you live. NorCal isn't that cold so the thicker stuff may not be available. In Reno it isn't too hard to find. Aluminum sounds like a good idea and I considered it but chose fiberglass/epoxy in the end. I may put an aluminum skin on the nose anyway. Just more protection. Try calling building contractor suppliers, someone suggested roofing suppliers and contractors too
Mel
atahoekid
Images: 158
Postby deleted » Mon Oct 29, 2012 7:51 pm
Thanks for the tips atahoekid. Yes, the blue foam board. Unfortunately neither Lowe's or Home Depot sell it here. I'm going to call Dow tomorrow to find out if anyone in the Bay Area does. Crossing my fingers that it won't be too hard to find.
deleted
Images: 85
