Landman76, welcome to the forum, from a transplanted Rockfordian, (is that a word?) from Northern Ill. I am going to make it real easy for you to accomplish your build with little or no problems. The following is a complete set of construction plans and a list of everything needed to completely build a little woody:
This list includes all of the wooden members, shaped plywood, bent exterior trim, templates for the fenders, tongue box, interior cabinet sketches, galley components, door and hatch-hinge hardware, wooden plug count, quantity of varnish needed and related items: Just scroll down.
Naw, just kidding, you don't need no stinking plans, just design and build to your heart's content as many others have done. We have a wealth of info, as you are aware, right here on this board, so bolt some stringers down on the trailer, glue and screw a 4x8 sheet of plywood down and start dreaming.
First off, cut out a cardboard full-size template of your intended shape and tack it to the edge of the floor. (it's a lot easier making changes in cardboard, than it is in already-cut plywood). Lay down on the floor with your Sweetie and draw out where you want the cabinets and galley wall to be. Can't wait to see the progress pics, and hope you post em as you go along. I have only 2 suggestions: make sure it has 2 doors and make them as big as possible, you'll be glad you did. Good luck on your build, and try to attend some of the midwestern gatherings back there. TDers are a friendly bunch and you can get loads of ideas and free advice.
Roly
