Hello from Manitoba, Canada
Postby starkayak » Mon Feb 07, 2011 8:40 pm
Hi there!
I found this place because the last trip I took on my 1100 Yamaha was a blast - except for the camping. I was towing a home-made trailer that was so hard to take down on the chilly mornings that it was NOT fun!!
This year, I want to camp in comfort - minimal set-up and take down. I love these teardrops, but I'm not sure any of them are light enough for me to pull with an 1100.
I have been looking for a while now, and decided that I should just ask the 'experts' on here! Are there any trailers out there that I can pull?
:roll:
P.S. I'm female, over 50, and not very good at building...
starkayak
Postby CarrieS » Tue Feb 08, 2011 11:16 am
Welcome! We also have a 1100 and have been wondering the same thing.
CarrieS
Postby bobhenry » Tue Feb 08, 2011 1:19 pm
My 1200 goldwing handled "Eggbert" a 3x5 cargo on a 40 x 48 HF frame.
This was an early picture ~~~almost 5 feet was added to the tongue and to level the towing height I later replaced the 12" tires with 8"'s to make towing height level.
I am currently building a 4x7 on a very light 125# all aluminum frame. I have towed it also and it seems to be very well mannered as well.
Two things must be mentioned braking on 2 wheels is very touchey. Any water, spilt oil, or gravel could have dire consequences in a panic stop. You have to ride like you are on snow and ice in these conditions.
The second thing the trailer must have a very very exagerated tongue to minimise side load. When one trailer wheel drops into a pot hole or swale it tends to flip the tongue sideways. You will swear someone grabbed the handlebars when you wern't looking.
I am setting the 4x7 up as a sleeper only teardrop. I will use a 10 x 10 pop up over it as the "Living room" when camping and the trailer will be the bed only after unloading the cargo.
Postby starkayak » Wed Feb 09, 2011 7:12 am
Thanks for the info!
Do you have plans for the 4x7 or are you just 'winging it'? I am not too sure that I have the capability to build one, so was hoping to find a place that makes them really small and light.
starkayak
Postby bobhenry » Wed Feb 09, 2011 8:45 am
Maybe this will help.....
An early discussion with the assistance of Andrew and others.
http://www.mikenchell.com/forums/viewtopic.php?p=180832&highlight=#180832
Postby bobhenry » Wed Feb 09, 2011 8:57 am
oops I see Andrew's pictures are gone ......
Glad I saved them in my album......
My original thoughts
Andrew's improved drawing.
For A Motorcyle
Postby Richard S » Mon Mar 07, 2011 4:39 pm
Hi Manitoba!
I don't know if you have taken a look at the teardrop built by Lil Guy but the Rascal looks like it might fit your needs. Weight is only 490 lbs and 50 of which is on the hitch ball. Check out this web page:
http://www.golittleguy.com/teardrops/
Regards
Richard S
TearJerkers Manitoba Chapter Dir.
www.tearjerkers.net
Richard S
Postby starkayak » Mon Mar 07, 2011 9:19 pm
Thank you - yes, I did look at them. Thanks for the reply!
starkayak
Postby mcspin50 » Wed Mar 09, 2011 5:39 pm
Hi starkayak,
Welcome to the forum! I was born in Winnipeg and graduated from high school in Wawanesa way back in the dark ages...the late 60's...right in your neck of the prairies.
I'm attempting to build my teardrop trailer with the help of No. 3 Son. Some days I think I can, other days I think I'm crazy! Hope to be done by late spring or early summer.
I hope you're able to find something that will work with your motorcycle and your budget. There's lots of folks here to give you sound advice on anything teardrop-related.
Heading up to Winnipeg on the 19th to see Harry Manx in concert with my niece. Should be good. I might even get my accent back, eh. ;)
Take care,
Lil M.
In every walk with nature, one receives far more than he seeks. - John Muir
Generic Benroy Build Journal here - My LilScamper Update Journal here
The Lily Pad...Image My LilScamper...Image Image
mcspin50
Images: 158
Users browsing this forum: Google [Bot] and 3 guests
