Plans for first build
Postby BrandonCormier » Sat Apr 30, 2011 1:02 pm
Ok. So I have decided on a design from the library. I want to build a version of "The Simple". 10' long X 4' high X 52" wide (inside).
I will be building on a frame from a 1986 Palomino Mustang pop-up camper. i will have to widen axle. I have mad welding skills, so frame modification is not a problem. (I have been welding for the better part of 25 years) :duh:
I will be using plywood for the shell. My concern is protecting the plywood. I did some research on different epoxy type coatings. Some products look like they will do the job. It seems that I would have a plastic coated camper with the epoxy. I have read some past posts on epoxy type coatings, but I was wondering if anyone ever used "Goop Coat-It"? I have a friend who used it on his mudboat, and that stuff is tough as bed liner and doesn't add too much weight. I think it would be a good coating on my TTT. It is paintable. Opinions? Comments? Pros-Cons? :QM
Although I am still in planning, blueprint, information gathering stage; I am gaining all the knowledge I can. This will be my first build and I want to be ready. :banana:
BrandonCormier
Postby mikeschn » Sat Apr 30, 2011 1:07 pm
If you are still collecting plans, check out the Generic Benroy Plans up there in the menu! Oh and welcome to the forum!
Postby v65infla » Sun May 01, 2011 10:50 pm
The Goop looks like good stuff. I am going to build a "Foamie" to pull behind a motorcycle and have been searching to find an outer shell. I realize there would have to be something between the Goop and the foam but that is the easy part.
I see that that it is sandable and paintable. Can it be sanded smooth like fiberglass??
Jamie
Boynton Beach, Fl.
v65infla
Yes
Postby BrandonCormier » Mon May 02, 2011 6:34 am
My buddy sanded it smooth on the bottom of his mudboat. It was real smooth and looked good painted. I believe it will be what I will use on my trailer.
BrandonCormier
Postby deepvee » Tue May 03, 2011 4:07 pm
Welcome to the site Brandon. So what part of the south your from? We have a group of us in the Gonzales area with the TearJerkers. We will be at Tickfaw state park this weekend. If you get a chance stop by and check it out.
Lester
deepvee
South
Postby BrandonCormier » Wed May 04, 2011 5:55 am
I actually live just south of Thibodaux. The gathering is at Tickfaw State Park? The wife and I may take a day trip to check out some of the campers and maybe get a few secrets from some of the "pros".
BrandonCormier
Postby deepvee » Wed May 04, 2011 6:38 am
P.M. sent. Yes we will be at the state park.
Lester
deepvee
