Introducing myself...
Postby VermonTear » Wed Nov 16, 2011 2:32 pm
Hi.. I've been browsing this forum, along with every other link google could provide, for the past month or so, as I contemplate building my first teardrop. Now that I've settled on a 4x8 cross between Grant's Lil Bear and Steve Frederick's Peg's Custom, I thought it was time to join this forum before I started begging you for answers to my myriad of questions.
I've done a fair amount of woodworking -- designed and built a couple of custom kitchens, torn the roof off an old farmhouse and replaced it with rough-sawn lumber I harvested from the property. But building a teardrop, electric (wow-- 12 volts), axles, wheels, aluminum roof -- there's going to be a lot new.
I've already found a lot of answers -- or places to look for the answers by snooting around here. Thanks for being here and sharing your good times and your bad.
I'll be in touch.
Ken
My first build 12/2011: viewtopic.php?p=890137#890137
VermonTear
Images: 149
Postby Big Dan » Wed Nov 16, 2011 11:56 pm
Welcome and good luck.
"Happiness is only real when shared" Alexander Supertramp
Big Dan
Postby Woodbutcher » Thu Nov 17, 2011 8:09 am
Welcome to the forum....you are in the right place if building a Teardrop is your plan. Good luck and post lots of pictures as you go!
Woodbutcher
