Greetings earthlings
Postby fishnpinball » Fri Jul 18, 2014 5:45 pm
I am Norm from North Central Kansas. I am getting very interested in teardops and working on deciding whether to build or buy one. I am afraid of my skill level on a build as I have none and probably not much support in this general area. I am retiring soon and want to spend time fishing and with pinball machines. hmmm may have to design the teardrop to be able to transport a pinball.
Norm
fishnpinball
Re: Greetings earthlings
Postby Hogdaddy » Fri Jul 18, 2014 6:47 pm
Build a houseboat instead.
Hogdaddy
Images: 15
Postby fishnpinball » Fri Jul 18, 2014 8:15 pm
They are too much hassle to take around to different areas! I want simplicity, ie teardrop would be nice. Probably a fishing kayak for a boat.
fishnpinball
Postby Caveman1970 » Sat Jul 19, 2014 7:32 am
I vote for building a pinball machine into your rear Galley! play a few games while your coffee is brewing!
"If at first you don't succeed....Caulk it!... A-lot!"
Caveman1970
Images: 26
Postby fishnpinball » Sat Jul 19, 2014 3:51 pm
I could actually make that work, but would I get any peace if I used a campground?
fishnpinball
Postby PKCSPT » Sat Jul 19, 2014 5:04 pm
fishnpinball wrote:I could actually make that work, but would I get any peace if I used a campground?
Nope,, a teardrop attracts attention anyway,, put a pinball machine in there and they will look at the tear and never leave.
121172 116946 159644
PKCSPT
Images: 61
Postby fishnpinball » Sat Jul 19, 2014 7:12 pm
Might be worth setting it up as an optional item to put in. That way when you are wanting the attention you can get it. It would get some attention at teardrop gatherings for sure. I figure on boondocking most of the time so it would not be usable most of the time. The newer ones draw around 6 amps at 120V and peak about double that. Not something to power off a battery/inverter. It would also add a lot of weight. Up to around 600 pounds for newer units. Maybe 400 pounds for an older electromechanical.
fishnpinball
Postby bc toys » Sun Jul 20, 2014 7:47 am
Welcome Norm to a great site
bc toys
Images: 42
