Hello from Dallas! Now, about those canvas-backed foamies?
Postby Patti » Wed Mar 11, 2015 10:00 am
I get the 'foamie' part but not the canvas part. Why use canvas? How is it treated? Do you paint it and/or decorated it? Is the canvas texture still visible once it's done?
We're looking to buy our teardrop--not enough time or stick-to-it-ness to build or restore our own. Instant gratification is our game. But I am loving watching everyone else here go through the process!
Patti
Re: Hello from Dallas! Now, about those canvas-backed foamie
Postby bc toys » Wed Mar 11, 2015 10:39 am
Welcome Dallas from Las Vegas Nv don't know a thing about foamies or canvas just welcoming you to this great site
bc toys
Images: 42
Postby pchast » Wed Mar 11, 2015 9:31 pm
Patti,
Foam is strong in compression and needs a skin to impart
greater strength. The skin, normally a canvas, helps
maintain the sculpted form. Other skins are being used and
tested. I've read about cotton and linen fabrics, Paper and
plywood being used.
The structure is similar to a cored and glassed boat construction.
Its been likened to an I beam. The skins separated by the foam
as the web.
I personally applied the canvas with a paint primer after the foam
was lightly scuff sanded. The canvas was then primed before the
addition of 2 coats of exterior latex paint. Hope the explanation
helps.
Others may, likely, explain it better.
pchast
Images: 97
Postby Patti » Wed Mar 11, 2015 10:23 pm
Does the canvas supply the exterior or do you cover it with aluminum or something else?
Patti
Postby Patti » Wed Mar 11, 2015 10:32 pm
I went and looked at your build pics and saw you and your wife stretching the canvas. Fascinating!
I'd love to see pics of the inside!
Patti
Postby tac422 » Thu Mar 12, 2015 8:22 am
Patti wrote:Does the canvas supply the exterior or do you cover it with aluminum or something else?
The painted canvas does become the exterior, and doesn't require any other covering.
I used a "less coarse" canvas, and the texture barely shows through. Another coat of paint on the sides would certainly hide the texture completely.
The texture shows through on the roof where I used aluminum paint, but it is a nice effect.
Here's where I started the canvasing on the Big Pink:
viewtopic.php?f=55&t=56441&start=75
tac422
Postby Racquetman » Thu Mar 12, 2015 2:16 pm
That is a beautiful trailer Tac, nice job!
Racquetman
Postby Patti » Thu Mar 12, 2015 6:29 pm
Tac, that was fun to page through and see the 'big pink' grow! Looks wonderful.
Patti
