Salvaging a trailer
Salvaging a trailer
Postby Doublacola » Mon May 11, 2015 1:13 pm
Hey everybody have a question.
I'm salvaging a 2011 K-Z sportsman travel trailer for the parts and 2 parts on the roof seem to have been hot glued on. A vent with fan and a TV antenna. Any ideas how to remove the glue? I mean this stuff is tough.
It also has a 4'x6' slide out that works if anybody is interested. Too big for my trailer or I'd try it.
Richard
Doublacola
Re: Salvaging a trailer
Postby Prem » Mon May 11, 2015 4:38 pm
Heat it.
My goal...
...is to live in a trailer.
Prem
Images: 144
Postby Doublacola » Mon May 11, 2015 6:37 pm
Prem that's a great idea! Thanks
Richard
Doublacola
Postby Woodbutcher » Mon May 11, 2015 6:57 pm
If it's got a plastic flange be careful. I would heat a putty knife and try to work it into the seal.
Woodbutcher
Postby dales133 » Mon May 11, 2015 7:03 pm
Maybe just keep cutting the glue in the same spot with a sharp blade, that or heat as previously mentioned
dales133
Postby hankaye » Mon May 11, 2015 9:34 pm
Doublacola, Howdy;
Rv roof huh ? Is it a rubber roof? If so then the most likely glued it down with
Dicor's self-leveling sealant. It is NOT a silicone as silicone and rubber roofs
don't like each other.
Take your utility knife and just cut along the edge of whatever you want to remove
look around for screws or other fasteners they may be hiding below the sealant. re.,
the tv antenna, undo all the bits on the inside of the RV first. As for the vent there are
some things inside that might hang you up also. Drop the trim ring and have a look-see.
Then you can do your Incredible Hulk impression and rip them off the roof off.
hank
hankaye
Postby Prem » Tue May 12, 2015 10:25 am
If that don't werk, get out a big ol pry bar and whomp on it.
:cigar:
My goal...
Prem
Images: 144
Postby tac422 » Tue May 12, 2015 4:00 pm
Have any pictures of the slide out ? :D :twisted:
tac422
Postby Doublacola » Wed May 13, 2015 7:21 pm
Here are a couple of pictures of the slideout.
Doublacola
