Fiberglass insulation on the roof
Re: Fiberglass insulation on the roof
Postby lrrowe » Wed Jul 05, 2017 2:47 pm
In my Car Mate, I used sheet foam glued to the aluminum ceiling and then Roxul insulation below that. The Roxul is not supposed to absord mositure. To date I have no complaints.
Bob
lrrowe
Images: 439
Postby walkrdg » Thu Jul 06, 2017 3:34 pm
Irrowe,
Can I ask what you're using for spring-boards to prop up the insulation? I've seen that done before, but can't tell what they are. I thought they might be furring strips, but then... are they 1x2 or 1x3, or 1x4... or something different altogether? I'm ready to cover the ceiling with wallboard I bought, but I don't have enough arms to go around. My wife will be happy to help, but that's probably still not going to be enough to hold the boards up there while I try to get some screws in.
Thanks, Dave
149397
walkrdg
Images: 7
Postby lrrowe » Thu Jul 06, 2017 5:08 pm
Probably most were 2x2's or anything I had laying around. The adhesive sort of held the panels in place long enough for the support strips to be setup. When I added the Roxul, I had cross strips tacked in place which held them up til the ceiling panels were added.
Edit....1x2's, not 2x2's
Bob
lrrowe
Images: 439
Postby MXD » Fri Jul 07, 2017 8:41 am
I ended up going with the Roxul. It's very east to shape and work with, I was impressed. Now to pull the cabinets off the front wall and insulate the cap.
MXD
Postby HotRod1 » Sat Jul 08, 2017 9:24 am
Why don't you just spray foam it? Even a 2" barrier would help. I had semis in south Texas and that's what I did. I gutted the interior, spray foamed the cavities. And reinstalled the interiors. With just the factory AC, you would need a jacket after a time.
I plan on sliding sideways on fire yelling what a ride when the Lord calls me home.
HotRod1
