Jeff's Cargo conversion
Re: Jeff's Cargo conversion
Postby BC Cargo » Sun Feb 12, 2012 3:21 pm
Lots of good work and sleepless nights thinking about this project I can see.
So if you were to un latch the pin at the bottom of the open door and move it away from the trailer about 3 feet…then with a new bracket on the top left corner of the door and one on the trailer top side rail you could slide over each bracket a 3 foot shower rod and quick pin secure. With the addition of a shower curtain it would give you a nice large shower stall (depending how far forward you mount the trailer bracket). But I am sure you have thought of that…because of your shower outlet location.
:thinking:
BC Cargo
Images: 87
Postby pete42 » Sun Feb 12, 2012 3:30 pm
Jeff
Nice build, when I was stationed in Long Beach back in the early 1960's I often stayed with my aunt and uncle in Redlands.
I still remembered the aroma of the orange trees that came from the many groves along the interstate from LB to Redlands.
we went back in the 1970's for a visit most groves were gone replaced with housing slabs of concrete
last time I was there in the 90's almost every orange grove had been replace with housing and the concrete slabs were now houses.
cousins and friends still live in Redlands, Riverside, San Diego, and san clemente.
nice job on your build keep the pictures coming.
pete
pete42
Postby Taco Jeff » Thu Apr 26, 2012 10:05 pm
Kitchen is done.
I should get my water tank this week.
Then on to the interior.
Jeff
Life should not be a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside in a cloud of smoke, thoroughly used up, totally worn out, and loudly proclaiming "Wow! What a Ride!"
— Hunter S. Thompson
2000 Landcruiser 100 series, 5X10 Haulmark Cargo Conversion, Heart attack survivor 2/22/2010
Taco Jeff
Postby sgip2000 » Thu Apr 26, 2012 11:11 pm
That galley looks awesome!
sgip2000
Postby pappaw » Fri Apr 27, 2012 10:35 am
Hey Jeff:
Wow, thats sweet :thumbsup:
Very nice job. 8)
Cheers: Jeff :beer:
Image Cheers from Granny, Pappaw, and Cocoa (the Dachshund) Image
pappaw
Images: 14
Postby nuclearfly » Fri Apr 27, 2012 12:19 pm
+3 Wow. I love that stone. Is that just regular wall tile? How heavy?
nuclearfly
Postby SteveB » Fri Apr 27, 2012 11:09 pm
Jeff, nice work. I am anxious to see what you do on the inside. You might give some thought to adding the capability to lock your rear doors open at 90 degrees to the galley wall. I found that it helps block a good portion of the wind that sometimes comes up while cooking.
SteveB
Postby Taco Jeff » Fri Apr 27, 2012 11:17 pm
nuclearfly wrote:+3 Wow. I love that stone. Is that just regular wall tile? How heavy?
That is Air Stone from Lowes. That backsplash weighs half what the P Lam counter top weighs.
Jeff
Taco Jeff
Postby Gadget Man » Sat Apr 28, 2012 10:04 pm
Wow, So far do Good....
If I wasn't building a toyhauler version of a trailer, I would have gone with barn doors on back and done something like you did.
Tell us more about that trailer hitch set-up.
Gadget Man
My kids may be smarter than me,
But I know more.
Gadget Man
Images: 23
Postby Taco Jeff » Sun Apr 29, 2012 8:09 am
This is the coupler: http://www.kilbystore.com/maxcoupler.html
They are used on most of your off road trailers here on the west coast.
They take some work to retrofit onto an existing trailer, but are worth it.
They also make it harder to steal the trailer.
The rear doors are my creation. Not barn doors. I took a single door, cut it in two, made steel frames and then put it back as bi-fold so the latching door folds back to secure to the step and hold it in the 180 degree position.
Thanks.
Jeff
Taco Jeff
Postby Taco Jeff » Mon Jun 18, 2012 10:18 pm
Electrical is almost done. Waiting for the inverter to arrive and then I will start on the cabinet to wrap things up.
Jeff
Taco Jeff
Postby Taco Jeff » Mon Jun 18, 2012 10:29 pm
Water tank is in. 33 gallons @ 8.34 Lbs. =275 Lbs. Wow, I should have seen that coming. Good thing it is as low as you can go.
Tank is 27 gallons and water heater is 6 gallons.
Jeff
Taco Jeff
Postby b.bodemer » Tue Jun 19, 2012 6:42 am
Awesome kitchen................
Barb
b.bodemer
Images: 328
Postby Goatdog » Tue Jun 19, 2012 6:22 pm
REALLY nice kitchen!
Goatdog
Images: 24
Postby roadinspector » Tue Jun 19, 2012 11:43 pm
Jeff[/quote]
One thing you can consider is not to fill your water until you arrive at location or somewhere close. This way you don't haul the extra weight. Most locations that have a sewer dump site has a water faucet there too.
Earnest
Dadgum it! I cut that board 5 times and it's still too short!
2001 quad-cab Dodge Cummins 3/4 ton camper special, 16x7x7 CT work in progress toyhauler, 01 HD Ultra Classic, 98 HD Heritage Softail, 88 HD 1200 Sportster. viewtopic.php?f=42&t=51510
roadinspector
Images: 127
