Flooring questions...if you had it to do over...
Re: Flooring questions...if you had it to do over...
Postby jeff0520 » Sun Nov 04, 2012 4:47 pm
We are going to go with vinyl flooring from the big orange box. It's cheap, easy, waterproof, and replacable.
Hypno-Toad's Command Post, the build thread! http://www.tnttt.com/viewtopic.php?f=50&t=50384
jeff0520
Images: 128
Postby bigbendhiker » Sun Nov 04, 2012 8:10 pm
jeff0520 wrote:We are going to go with vinyl flooring from the big orange box. It's cheap, easy, waterproof, and replacable.
I just got back from the big "blue" box with a roll of vinyl flooring and adhesive. I agree with your assessment above. If in the future I want to go with something else, it will be relatively easy to remove and replace.
Scott
bigbendhiker
Images: 28
Postby drsm » Mon Nov 12, 2012 8:17 pm
FWIW, here's another vote for the G-floor raised coin mat. It is easy to keep clean, comfortable to walk on (I'm a barefoot fanatic) and keeps things from sliding around under way. We just left ours floating, because we have only done our tentative build. It occasionally gets a bubble, but it hasn't been an issue.
drsm
