The hardest cut was the first one. STRONGLY recommend NOT using a Sawzall....the result was a little more less finished than I would have liked
Vent hose mounted to the floor
marine toilet .....waterless.....NO blackwater/ grey water, or fresh water
E-track on the sides at 22" high. Used 2x4 lumber brackets to hold 1.25" x 1.25" 14 ga tubular steel, cut at 79". There are a total of three 1/2" plywood decks. The top one (38" x 79") has a 5" twin topper on it covered in Marine Vinyl (on sale at Joann's Fabrics, less than $30). The top one will move to the upper Etrack (with 3 steel supports) leaving the lower two (40" x 79") to slide forward (moving the supports also). A queen air mattress will fit on this.
